03-02-2011, 07:52 PM | #26 |
Re: Summit lowering springs
Here ya go!!
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
03-02-2011, 08:18 PM | #27 |
67-72 parts collector,…
Measure your truck BEFORE and after you put them in.
(just to get an accurate drop measurement)
03-02-2011, 08:28 PM | #28 |
Definatley. I still have the measurements from the drop spindles but im gonna check it again anyway now that its had a chance to settle some.
03-02-2011, 08:31 PM | #29 |
I know the pieces fit
Mine had what appeared to be the original springs on the front before I installed those springs. I was wondered if the stock springs might be sagging so much that I wouldn't notice any difference with the Ground Force springs but was pleasantly surprised. It dropped the nose down nicely. Not slammed, but just what I wanted out of it.
Post up pics when you are done, hope they work as well for you. |
03-02-2011, 09:35 PM | #30 |
Please Please Please get some measurements. Before and afters from spindle or wheel center to the fender lip straight up. I just finished 3" Beltechs and one coil an it's too low for me. I'm thinking 2" springs and matching th back. I think th one coil off turned into 3 inches instead of 2
03-02-2011, 10:00 PM | #31 |
Watch out for your cornhole !
On this subject, here are some pictures I took back when I was removing my Summit (Ground Force) 3 inch springs and swapping in a pair of DJM 2 inch springs.
03-03-2011, 12:20 AM | #32 |
.. !WAR FEDOR! ..
Wow...
"san diego chargers #1" |
03-03-2011, 12:32 AM | #33 |
I don't know if it would make sense if we made a calculation of the springs with my stock ones but here they are. Now that I look at them I can see why there was a lean. Not the two lower coils ar not the same spacing, and I did have a fitting issue on the top pockets.
03-03-2011, 09:44 AM | #34 |
Here is a pic with a tape to my new ones.
03-03-2011, 10:58 PM | #35 |
So measurements from the center of the wheel to the fender, please please please. Oh yeah and measurement of the shocks too. Oh yeah get to work. Results results results!!! Pics pics pics.
03-07-2011, 12:55 PM | #36 | |
I just ordered a set of 3in. dropped springs from POL. They're suppose to be moog springs. I am concerned now about installing them. I'm goin to try them and see how it works. My main concern is the alignment. |
03-07-2011, 10:52 PM | #37 |
I think you made an ok chioce. I've been debating whether to toss my 3" beltech spindles with the wheel fitment problems I've had, but not yet. I don't know about the ride of the 3" lowering springs but I do have an easy fix for keeping the springs in place. They are much shorter so you need to decrease the downward travel of the suspension to keep tension on the spring at all times. So the easy fix is to put a larger bump stop on the bottom side of the upper control arm. This will stop the suspension from letting the spring come loose from it's intended location when jacking it up or going airborn lol.
And yes we want pics! |
03-08-2011, 12:02 AM | #38 |
My trucks 5/5 and its pretty ruff on any bumps new shocks 3 spindle 2 spring and a rear 5 flip with new shocks trimmed bump stop 1/2'' and help to get a nicer ride would be appreciated . I was going to switch to 1'' lower spring instead of 2''
03-08-2011, 08:54 AM | #39 | |
Brandon |
Thread Tools | |
Display Modes | |
