Summit lowering springs
Any one used these? Wondering how much drop they actually give since it says 1-3.
http://www.summitracing.com/parts/SUM-G726/
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
Re: Summit lowering springs
Nevermind answered my own question. Looked at the application tab and it said 3" drop.
![]() Join Date: Dec 2008
some say a 2" drop Springs or (cut a coil off stock springs) with spindles for additional drop.dont quote me on that.
.. !WAR FEDOR! ..
Get them man, they will most lilkey be groundforce springs.
"san diego chargers #1" |
Happy to be here
![]() Join Date: Mar 2000
Get the 2" version, not 3". You wont like the ride of 3"....
Posted via Mobile Device |
#6 | |
Here is a link to the 2" ones if anyone is looking for some. http://www.summitracing.com/parts/SUM-G727/
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. Last edited by monte0185; 02-22-2011 at 03:16 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I love Summit brand springs. You're gonna like what you find inside the box.
I had some 1" lowering springs located from a website, but I can't find it again. Has anyone seen some?
I have car A.D.D.
I have the Summit branded springs on my truck. Just like the pictures posted above, Ground Force springs. I don't mind the ride. But thenm again, I had a Jetta about 6 years ago that had coilovers on it and rode like a go kart.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
.. !WAR FEDOR! ..
yeah, i had the 3''s before and they sucked, i went with the 2''ers.
#11 | |
Frank
Born and proudly residing in a Red State ! |
#12 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
The ride should be fine, with the correct drop shocks, and trimmed bumpstops. The height of the crossmember from the ground, is the real issue. I see tons of members install a 3/5 "spring only" drops on their trucks, because it's an affordable drop. No one complains about the ride quality. BUT,... when you add a 3" front spring to a drop spindle,... everyone acts like it's some kind of voodoo! Anyone going with an 5"-6" front drop has to realize there are going to be issues with the inner fenders, front tire height, and speed bumps. So what's all the ride quality concerns?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-23-2011 at 01:14 PM. |
#13 | |
.. !WAR FEDOR! ..
#14 |
Man y'all got me concerned I'm going too low. Guess Ill find out huh. Ordered the springs and drop shocks this AM. Think i might go to harbor freight this weekend and pick me up a jack. One of them fancy aluminum ones. Trick to their jacks are as soon as you get them tear the pump apart and remove all the shavings and put it back together and it'll last awhile then.
#15 | |
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#16 | |
Happy to be here
The spring is too short to allow for decent travel. Adding the right shock helps some, but not enough. My experience has been that a 3" drop spring is just not a good choice.
#17 | |
#18 | |
That said, it was the spring itself that was the problem. I can cut a stock spring 1 coil to get 3 inch drop and it rides fine, but those custom 3 inch springs are way too stiff. I will never buy another set of 3 inch lowering springs after that. If I want three inch drop I'll modify the stock springs. Scoti warned me about this and he was 100 percent right.
#19 | |
I value your opinion, as well as SCOTI's and other's here. Now it sound's like it's boiling down to just the 3" spings,... period? Or just this Ground Force/Summit brand of 3" spring? I too have run stock "cut" springs with a 3" drop. I've also trimmed 2" drop springs to create a 3" drop. I have a set of these Summit 3" drop springs in my red '69 right now. (I've only driven it about 50 miles, though) Just trying to understand, if it's just these springs or all factory manufactured 3" drop springs that everyone hates? Sounds like the Summit brand is out. What about other brands? Any other members, running 3" drop springs,... want to chime in?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-24-2011 at 07:50 AM. |
#20 |
Happy to be here
Its been a while since I ran a set. I know it wasn't Ground Force, so its not just the brand. What I do know is Kevin is 100% correct that Ground Force makes a good spring but not in a 3". Scoti and I have compared notes along with many others who have had a similar experience with various brands of 3" springs.
The general consensus is that cutting a stock spring to gain a 3" drop works just fine, but a 3" lowering spring does not.
#21 |
Happy to be here
I am saying its too stiff and bottoms out. Even the young guns don't care for them, so I think thats pretty stiff.
#22 |
I know the pieces fit
I like mine, the only qualifier is that they will bottom out on a bad bump if you don't trim the bump stops. But the ride is good.
#23 |
Well they should be sitting on my driveway when i get home today so hopefully Ill get them put in this weekend. The 2" ones not the 3" ones. Anyone want some pics of them?
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. Last edited by monte0185; 03-02-2011 at 03:13 PM. |
#24 |
Happy to be here
Of course we want pics
#25 | |
.. !WAR FEDOR! ..
