Old 12-24-2004, 02:32 AM   #1
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
Question how much will it drop
I would like to lower the rear of my 67 about 2 inches. It will never be a show truck,so i am considering cutting the coils. How much will it lower if 1 ring is removed?Should i use a cut off wheel as opposed to a torch?
mblackburnjr is offline   Reply With Quote
Old 12-24-2004, 04:36 AM   #2
68LSS1
68LSS1's Avatar
Mine went about 1 1/2". I wouldn't go more than 1 coil as these are not progressive/variable rate springs. Any more will really effect the ride. Use a torch and cut the spring. Then heat the coil about 1/4 to 1/3 from the end of the cut and then quickly turn over and set it on the ground and push down so that the last coil will be flat on the top like it originally was. Do not quench, allow it to air cool slowly.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 12-24-2004, 08:45 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you cut the rear coils, you need to do more than that. The rear coils are tapered on each end. You have to modify the mounting of the coil if you cut the pig tail off of the end of the coil.
For a 2 inch drop, lowering blocks are way easier.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-24-2004, 11:35 AM   #4
mblackburnjr
Thanks for the help guys!
Old 12-24-2004, 03:15 PM   #5
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
I had a 68 that I heated the rear coils with a rosebud. Just blocked under the frame on perfectly flat level ground, left a gap between blocks and frame the amount you want to lower it. Heat don't heat the entire coil just slowly heat and transfer from side to side don't drop one side at a time alll the way. heat just upper coil wrap, and keep moving down untill desired drop is acceived. I drove my truck for a year or so after, no problems, and ride was not changed.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 12-24-2004, 04:53 PM   #6
Shane
Shane's Avatar
If you are only going 2 inches, why not use blocks? You will still have full springs and you still acheive the drop you are looking for.
Just a thought ....
Shane is offline   Reply With Quote
Old 12-24-2004, 05:48 PM   #7
XXL
Seņor Member
XXL's Avatar
Originally Posted by bagged72blaz
I had a 68 that I heated the rear coils...
Not a recommended method.
XXL is offline   Reply With Quote
Old 12-24-2004, 07:43 PM   #8
crazy longhorn
Fabricate till you "puke"
3rd the block deal....try to stick with 2 - 2 1/4" on the block , if you are running 15" wheels......that way, if by chance you blow a tire, you wont have suspension parts draggin on the pavement best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-28-2004, 09:14 PM   #9
jalopy tz
Are these block's the same one you use on leaf spring's or these block's diffirent for control arm's need pic's please. I like this idea so that I dont have to cut or heat my coil's. Me and my friend were talking about this subject the other day. He also want's to lower his truck and keep his ride smooth. "jalopy tz"
jalopy tz is offline   Reply With Quote
Old 12-28-2004, 09:48 PM   #10
Tx Firefighter
Do a search for blocks. I've posted a picture of them lots of times on other threads.
Old 12-28-2004, 11:15 PM   #11
me3
hart
strange when I asked that ? I got about thirtys NO DONT DO IT YOU COULD HURT YOURSELF. bs I was "complaining" about putting a carb kit in let alone $400 on spring right now.
me3 is offline   Reply With Quote
Old 12-29-2004, 02:31 AM   #12
68LSS1
68LSS1's Avatar
That just goes to show you have to take advice from the internet with a grain of salt. And it doesn't matter if someone has 2 posts or 2,000 posts. Sometimes questions are hard to ask and even harder to answer. It's easy to assume. For example look at my response above. I assumed the mblackburnjr had thought about using lowering blocks but for some reason didn't want to. Some people don't like blocks, me being one of them. Tx Firefighter pointed out because the coils are "tighter" on the top and bottom and fit in the retainers that more would have to be done. For some taking a piece of 3/16" steel and some solid stock to make a retainer in a hour isn't a problem but for others it could be. The upper springs don't need to be held to the frame, just a means to keep them from sliding out from under it (in fact my HTH kit just has the springs in cups at the top also, no other form of retention at the top). I will argue against anybody that says you can't cut springs but it does create another issue with the springs are trucks use. I wouldn't argue for heating them either. I guess it depends a lot on who answers your posts but overall I'd say this is one of the better forums I know of and I know nobody intentionally meant to mislead you. A lot of people means a lot of ideas of what's right or wrong or what can and can't be done.
'68 Short Step
