1694AA Parchment Trim
My 71 Jimmy lists this on the id tag on the glovebox door. Is "trim" used to describe the interior (ie seats, dash pad, carpet, sunvisors etc)? Also, what exactly is parchment? None of the brochures show color combos that I've found. I'm thinking it's a tan color. If it matters the outside was medium olive green. The interior is pretty much none existant or what's left is black now.
'71 ![]() "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
Resident Curmudgeon
![]() Join Date: Dec 1999
Trim is the vinyl and/or plastic interior components such as door panels, arm rests, dash pad, seats and sun visors.
Parchment is white or off-white if you will. Saddle is the tan
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
SKINNY TIRES RULE!
My blazer has the same combo. I have off-white seats, visors and door panels. The dash pad, steering column and top of dash are all painted Sandalwood, which is a lighter tan than Saddle. I have the rubber flooring so I don't know what color the carpet would be. There is a code on the rubber flooring for Parchment (along with several other) but the rubber flooring is black.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Thanks guys, that explains alot. The off white is fine but gets dirty too quickly for me, especially with an open top vehicle. If it had been tan originally I would have considered keeping it that way, I think the green and tan looks good and tan doesn't get dirty quiet as fast as the off white. Sooo, looks like black will be the color for me.
go cyclones
Mine was the same as bouncytrucks, white interior in a 4X4 what were they thinking
![]() ![]() Join Date: Jan 2002
My Jimmy has the same colors and it has dark gold carpet in the glove box it has that it came with gold trim and it has a paint # for the steering column and the top of the dash. When I bought a new steering wheel I had to paint it because the color was so fare off. I used the paint on the steering column and wheel and top of dash and it came out nice.
I can get the paint # if you want it
SKINNY TIRES RULE!
Pictures would be good!
I haven't ever seen reproduction parts in the Sandalwood color. Mothertruckers had some dash pads a while back, but I didn't have the $ at the time.
