Formerly yellow72custom
Engine is hard to start in the rain...
I have a 350 in my truck, with a edelbrock 1406 carb, and a 14x3 open element air cleaner sitting on the stock air cleaner spacer above the carb. My problem is, that whenever i drive it for a little while in the rain, it has a hard time starting back up. I will have to crank the motor over about 5 times as long as usual, and it dosen't want to idle just after you get it started. I'm guessing this is because it is getting water sucked into the air cleaner. I THINK that it isn't water in the distriubtor because it didn't do this with the stock air cleaner, and the engine proably wouldn't run at all with water in there. So, is this a problem that i just have to live with, or is there any way that i can keep water out of there?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
You might want to check if your distributor cap, coil and wires are dirty or dusty, it could be moisure causing crossfire and making it hard to start.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End Early Classics 6 Lug Disc Brakes and Spindles All Stainless Lines Last edited by Denny; 07-28-2002 at 06:05 PM. |
Thats just prime!
Yeah i'd have to agree with Denny, whenever i go through a big puddle and i get water on any of my ignition system components, (i think its my distributer) my engine bogs down and i have to rev it a bit to keep it from stalling.
*69 GMC short bed stepside with a wimpy six that can barely pull itself. *99 Chevrolet Camaro Z-28 1 Bad 5.7ltr LS1 |
Now the others dig........
![]() Join Date: May 2002
hmmmm
deffinately check the distributer......if it's wet....take a blow dryer to it. Maybe check the solenoid coil????I dunno....maybe.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
its all about the +6 inches
cap/rotor and maybe wires need chainged. Classic symptoms.
Ok, i was planning on giving it a tune-up anyway. Maybe it happening after i swapped air cleaners is just a concidince (sp?).
Thanks for the help ![]()
