Old 05-15-2005, 10:30 PM   #1
jamal
jamal's Avatar
engine swap question
I have a 1970 model gmc ton with a straight 6 292 engine that my grandad gave me, and am trying to fix it up. My question is what parts do I need to bolt a 350 into the truck and use the factory four speed with granny first. I have the mounts and manifolds for the engine, but really wanted to know about the bellhousing and if I need to change it, and anything else I may have looked over like clutch linkages ect
jamal is offline   Reply With Quote
Old 05-16-2005, 07:19 PM   #2
jamal
jamal's Avatar
come on guys, somebody has to know
Old 05-16-2005, 09:24 PM   #3
shifty
Questionable
shifty's Avatar
It should bolt right up.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-16-2005, 09:38 PM   #4
jamal
jamal's Avatar
Thanks I put the engine up in parts forum, but if I can't find any takers I will try it and see, thanks a lot. I did a 6 to v8 swap in a 77 camaro with a turbo 350 and didn't change anything, but didn't know about the manual tranny.
Old 05-16-2005, 09:41 PM   #5
shifty
Questionable
shifty's Avatar
If all you're doing is swapping the engine and they're both older model engines, I've had several people tell me it's a bolt-up job if you have the right mounts and the number of splines on the tranny are the same. You might mount to a diff't spot (the L6 and V8 engines use different mount points on the frame, I'm pretty sure). You can probably use the existing bellhousing. Hell, I just got a 4spd manual tranny from an '84 van or something and it bolts right up to my bellhousing for my 3spd saginaw tranny.
Old 05-16-2005, 10:03 PM   #6
jamal
jamal's Avatar
thats what I needed, thanks, I believ I will make the swap thanks a lot that was very helpful
