Old 05-20-2005, 05:17 PM   #1
midyearvet@aol.
Power Brake Booster Braces
Does anyone have a picture of their firewall with the Power Brake Booster mounted and the braces attached? I need to see where they attach to the firewall.
Thanks Rick / Ca.
midyearvet@aol. is offline   Reply With Quote
Old 05-20-2005, 05:38 PM   #2
Back in Black
brace question
I know one bolts to one of the bolts for the emergency brake. The other maybe to the booster mount
Back in Black is offline   Reply With Quote
Old 05-20-2005, 06:53 PM   #3
midyearvet@aol.
Braces
Thanks for the quick reply.
Regards Rick
Old 05-20-2005, 07:06 PM   #4
Gee_Emm
Here are some pictures, note the 2 braces.
Gee_Emm is offline   Reply With Quote
Old 05-20-2005, 07:10 PM   #5
Gee_Emm
Found some more
Old 05-20-2005, 07:18 PM   #6
midyearvet@aol.
Braces
Exactly what I needed.
Thanck You
My truck came with Power Brakes, But never had the Braces on it.
I'm replacing the booster, Master cyl. & brake lines and I thought I should make it right.
Rick / Ca.
Old 05-20-2005, 09:56 PM   #7
c10chevy69
c10chevy69's Avatar
Do you need to have both? I just have the top one on mine.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug
c10chevy69 is offline   Reply With Quote
Old 05-20-2005, 11:08 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'm pretty sure the braces were only on 71 and 72...never seen them on anything older
Old 05-21-2005, 10:34 AM   #9
midyearvet@aol.
Braces
That explanes it. My truck was a 70 origionally. I converted it over pretty much to a 72 over the years. And now for the brake booster.
Rick / Ca.
Old 05-21-2005, 03:38 PM   #10
byrd
Union Electrician
byrd's Avatar
So do you have to use the brackets? Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-21-2005, 10:41 PM   #11
chevytruckfan
chevytruckfan's Avatar
I don;t have any on mine and it works fine.
chevytruckfan is offline   Reply With Quote
Old 05-21-2005, 10:55 PM   #12
midyearvet@aol.
Braces
I've had my truck for 35yrs without them, so obviously you don't need them.
Gm must have put them on the 71 & 72's for some reason, so I thought I would add them.
Rick / Ca.
Old 05-22-2005, 10:24 PM   #13
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
Rick, Braces At Your Age?
Heck, I didn't even know your teeth were CROOKED! HeHe! Must be workin' hard on that brake setup, haven't heard from you. Looks like I will be in the Valley in early AUG, I will let you know as plans firm up. Take care, The Rod
'67 Chevy Iron City Beer Truck (9ft step)
'67 Chevy Panel Truck 467
'68 Short Fleet 305v6
'68 McLaren Ramp Truck
'68/'68/'70/'71 Burbs 292/366/402/454
'69 C-30 dump
'71 C-50 dump and church bus
'71 4x4 454
'72 Blazer (w/pop-up camper) $15 x-hooks
'66 Chevy II 194/Weber
'68 El Camino" 305v6
'69 Skylark 455 Buick
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
"The 51" Chopped '51 Chevy (409) my first car
OK Toad, we'll take 'em all... John Milner
hotrodmtodd is offline   Reply With Quote
Old 10-27-2014, 03:34 AM   #14
tonyr0774
Re: Power Brake Booster Braces
I have recently performed the same brake system upgrade on my 68 k20. I had to find the 5&1/2 inch booster to firewall brackets from the j yard. While retrieving the brackets off of the 72 donor I noticed the two braces and decided to take them as well.
When I got the parts back I noticed there where no holes or studs on the firewall to mount them to. I was not able to see any photos on this thread for some reason. Does anyone have any or maybe some tips on drilling and fabrication to make them fit.
tonyr0774 is offline   Reply With Quote
Old 10-27-2014, 02:23 PM   #15
FirstOwner69
FirstOwner69's Avatar
The picture from my 69 below should help. The round brace goes to the stud ABOVE the arrow (not where it's pointing) along with the wire harness clip. The other brace will require drilling a hole for a bolt where the white circle is. There's probably a dimple at that spot. I suggest you check the precise location for the hole using your brace prior to drilling.
FirstOwner69 is offline   Reply With Quote
Old 10-27-2014, 02:57 PM   #16
Fitz
Thanks Rick / Ca.
The booster is a dual diaphragm type but uses the stock braces.
Fitz is offline   Reply With Quote
Old 10-27-2014, 04:37 PM   #17
68C15
blood type; Retumbo
68C15's Avatar
damn you Fitz, you made me drool on my keyboard again
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-27-2014, 06:51 PM   #18
Fitz
Get behind the wheel of that thing and you'll do more than drool. I took my girlfriend on a pass at the local dragstrip on test and tune night and she wet her pants.
