Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 05-25-2005, 09:42 AM   #1
Trifelynn
Trifelynn's Avatar
Help with rebuilding a Tilt Column
I just bought a tilt column and had some questions. It is not refurbished, first of all. I was looking through the F.A.Q. section for help on going through the column. Any info/pics/help would be appreciated. I am not sure how to tell what is still good, and what needs to be refurbished. I know some guys on here make a habit out of rebuilding steering columns. I would like to do it myself, so I know how to do it. Again, any help would be GREEEAAAAAATTTT!!!! thanks in advance
Lenny
Always looking for a 2wd blazer
Trifelynn is offline
Old 05-25-2005, 10:05 AM   #2
CUSTOM/10
CUSTOM/10's Avatar
Tilt break-down
This may help.
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline
Old 05-25-2005, 10:06 AM   #3
CUSTOM/10
CUSTOM/10's Avatar
One more
I stole these pic's from an old thread.
Gary
72 SWB 4x4
My 72 SWB Build
Old 05-25-2005, 11:09 AM   #4
Trifelynn
Trifelynn's Avatar
Thanks Gary...
that is very helpful. Now, next question is, what, if anything, can I use from a non tilt, to rebuild the tilt? Anyone know?
Old 05-25-2005, 02:00 PM   #5
71swb4x4
71swb4x4's Avatar
It would be easiest to list the parts that you want to use from the non tilt and ask. Most of the "vital" parts (bowl, bearings, etc) do not swap over.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline
Old 05-26-2005, 08:15 AM   #6
Trifelynn
Trifelynn's Avatar
That is the thing though. I don't know by looking and playing with the tilt, what parts need to be replaced. I mean, should I just go through and replace everything? I didn't know if there was a "general rule"...
Old 05-26-2005, 11:12 AM   #7
71swb4x4
71swb4x4's Avatar
I replaced the switch and all three bearings.
If you are going through it I would recommend replacing the bearings. The switch you can replace at any time without too much trouble, but if it's questionable you may as well change it now. The other part that commonly breaks is the shifter pointer, but if it's not broke now no reason to change it.
Once you tear into it you will want to look everything over but most of the internal parts are pretty heavy. I have only restored one column so I am not going by a lot of experience here.
71swb4x4 is offline
Closed Thread
