What's the recommended oil to use in the rear diff with a posi unit?
------------------ 72 c-10 lwb 350/4speed/3.73 posi
72 c-10 lwb 350/4speed/3.73 posi |
Weapons Of Construction
Chevy Garage has the stuff. Not sure of the P/N and I remember it wasn't exactly cheap.
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
Not sure if you need the additive for your posi, but my 96 required it. I got the gearlube and the additive for my 96 from the dealer.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
In the drivers manual for my GMC truck 910 from 68 it saies you need a special oil with pn. 5786991. I wonder if the number is stil in use?
75 Blazer K5 cab 66 Chevrolet Impala 2dht 68 GMC 4x4 pickup (project) 43 GMC CCKW 6x6 |
![]() Join Date: Feb 2000
Use 80-90 gear lube with the GM posi additive. If you don't use the additive then the clutches wear and the posi will clunk and make noise. I added it to my '72 and it quieted down and works much smoother.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
Thanks for the input.
Glowing since 1978
This is a very important subject. Here is a little of my history. I changed the rear end oil in my Corvette. I used an oil which claimed it was for GM posi rear and then the bad stuff started happening. I was young and thought that the rear end needed to be replaced because I would have to rev the 454 up to 2000 rpm when pulling away from a stop sign and turning. The cause was improper lubricant gumming up the clutch packs. I remeber my suprise when the Chevy dealer said it was ready for pickup and the price was like $30.00. Okay it was a long time ago. All they did was flush the rear out and put in the right gear lube. I think I have some in the garage. Special lube is GM1052271 and the additive is GM1052358. This is what was called out for my 87 Firebird or the Vette but I think you'll find this might also be correct for other limited-slip rears. The no-spin rear is a different story. I'm pretty sure you use 80-90 gear lube for that application. No clutch pack to worry about.
------------------ 66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 79 Chevy 4X4 (Tom's old truck)
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
