Old 08-08-2002, 09:35 AM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
Shift kit drilled for street?
I bought a shift kit for the TH350 in my old Camaro many moons ago, but never got the chance to install it. Well, it's dead now but I still have the kit. It's already been drilled for street instead of towing. Would it be ok in my truck, or should I get another one and drill it for towing?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 08-08-2002, 09:58 AM   #2
Smooth68
Smooth68's Avatar
depends if you want extra firm tire chriping shifts or just firm shifts...
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 08-08-2002, 05:00 PM   #3
68 with 350 TPI
68 with 350 TPI's Avatar
I always put in kits on the street/strip setting.
Makes the band hold a bit more and under load it helps.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 08-08-2002, 05:57 PM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
And will also help the trans run cooler. Less slippage = less heat
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 08-08-2002, 06:53 PM   #5
67 SS
I've always ran street/strip.It would shift firm while normal driving and bark the tires when you shift at upper RPM's.Not sure what the advantage of the RV setting would be.
67 SS is offline   Reply With Quote
Old 08-08-2002, 07:32 PM   #6
Beast388
Suburbans RULE!
Beast388's Avatar
Same here.....I installed my shift kit and used the street/strip separator plate. I've towed with it, it shifts hard and will chirp 2nd.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 08-08-2002, 09:56 PM   #7
DennyB
DennyB's Avatar
What brand of shift kit is it?
The B&M and TCI valve bodies will shift hard at all throttle points.
The trans-go will shift harder as more throttle is applied <-- I like this , But still shifts stiff at lower RPMs
Also it depends on if you want full manual, or manual/automatic.
I.M.O.M,W,J&C
Patriot Guard Rider
Old 08-08-2002, 11:33 PM   #8
RipMeyer
RipMeyer's Avatar
You cant even tell I have one installed unless you are full wide open. Then it chirps quite well.
RipMeyer is offline   Reply With Quote
Old 08-09-2002, 01:30 PM   #9
DennyB
DennyB's Avatar
What brand are you using?
I.M.O.M,W,J&C
Patriot Guard Rider
