05-05-2005, 09:57 AM | #1 |
Armor All in the engine bay?
I have wiped down my hoses and radiator shroud as well as
all other plastic parts in the engine bay for some time now and one of my buddies said this will weaken radiator hoses? Has anyone been doing this for a few years and were there any problems? .
http://www.netSnapShot.com/pcw/b?KEY=0&ACCOUNT=2551 72 SWB, 350, Edlebrock Intake Edlebrock Carb K&N Straight SS Pipes |
05-05-2005, 10:04 AM | #2 |
i have been for about oh, 7 years now. no problems yet.
https://www.ebay.com/itm/295742064443 |
05-05-2005, 10:56 AM | #3 |
67 is sold
Old Armor All will, the current products should be just fine
I use it on my GMC |
05-05-2005, 11:59 AM | #4 |
Confirmed Truckaholic
I think the old stuff had silicon in it, looks great but dries stuff out.
05-05-2005, 12:07 PM | #5 |
User #12137
i hope you people never have to paint anything that has had that crap on it (Armor All) just try to paint sumthing that has had it on there(even if its been sanded) and you will see what i am talkin about ,even over spray of that stuff will cause all kinds of problems ! just me 2cents worth and not meant to bash anybody
05-05-2005, 12:11 PM | #6 |
Questionable
I was always told it's the opposite of sex. For cars, you want to use an oil-based lubricant, not a water based lubricant. Armor All is a water-based product and water on plastics will promot fatigue and cracking.
Anyone is open to call BS on me, but ... this is what my regular detail guy always told me.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
05-05-2005, 12:28 PM | #7 | |
67 is sold
05-05-2005, 12:35 PM | #8 |
This was brought up in some aircraft tire training that I recently had that was presented by Michelin. Basically if you use it you must keep using it. It does have the ability to break down plastics, rubber, etc but that doesn't happen until whatever you used it on starts drying out. Meaning if you use it on your dash and then don't put it on for a few months, the dash will start drying out quicker and will become more brittle or prone to cracking than if you hadn't used it. But if you keep applying it then it will be fine. This would apply to tires also. He did gave technical terms and reasons why but this was quite aways into the class and I wasn't all there.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
05-05-2005, 12:50 PM | #9 |
67 is sold
I only use my left over Armor All in the engine bay and noplace else. I don't like how it attracts dust.
For my interior/exterior trim, I use nothing but 303 Aerospace Protectant |
05-05-2005, 01:20 PM | #10 |
not an amoror-all fan
05-05-2005, 01:44 PM | #11 |
Got Light Emitting Diode?
i also heard that armor all made what ever you put it on dependant on it, so i never have used it
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
05-05-2005, 03:58 PM | #12 |
I'd stay completely away from Armourall. Try a bottle of Meguiars # 40, I started using it @ 3 years ago and won't use anything else now, the stuff ROCKS! Doug
05-05-2005, 05:19 PM | #13 |
Armour all is GREAT stuff to use RIGHT before selling a truck or car! Anything that cleans up plastic and rubber helps the looks. Thank GM for our trucks not having too much of that Petro crap! Just do not get any on a floor surface or you may take an unexpected ride to the hospital! Thanks to all for the long term effects, my short term memory loss already forgot that trip!
1968 Chevy 4x4 307 4 speed Last edited by GMC AMI; 05-05-2005 at 05:24 PM. |
05-06-2005, 03:38 AM | #14 | |
Once applied to tires, vinyl, rubber stuff, etc, it can be wiped off for a dry surface, at least compared to Armorall. And it has a UV protector. I know of some convertible and soft top makers as well as boat canopy makers that recommend 303. Seems to last longer than Armorall, too.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
05-06-2005, 10:17 AM | #15 |
Thought this would be a good thread for over here. I've seen guys use Amoral and I've seen em use tire stuff. I just wipe mine down with a rag. Don't really have much rubber anymore under there.
05-06-2005, 10:20 AM | #16 |
What about ArmorAll tire foam? Is that the same as the dash crap?
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold ) |
05-06-2005, 03:26 PM | #17 |
#16876
" dont they put fiberglass shavings in there to cut into the finish?"
05-08-2005, 12:14 PM | #18 |
God Bless Mr. T
I have to say a ditto on the Meguir's...doesn't leave the dash as greasy feeling as armor all.
Like a midget at a urinal...sometimes you must stay on your toes. |
05-08-2005, 08:38 PM | #19 |
armoural anywhere near a ongoing paint project will give you fisheyes...is best avoided anywhere on the vehicle before painting or youll have headaches with finish because of it...heard this years ago so may not be viable with new products
05-15-2005, 04:32 PM | #20 | |
BlahBlahBlah
05-15-2005, 11:04 PM | #21 |
hahaha. how many bottles did you run down to the store and buy??
06-25-2005, 04:15 PM | #22 |
If you have an O2 sensor and get armor all on it, you might as well take it out and toss it in the garbage. Once the sensor is covered, it cannot compare the oxygen of the outside air to the exhaust's oxygen content. Used car dealers are notorious for screwing up an O2 sensor from all the armorall or clearcoat they spray under the hoods. Also, when tires are sprayed with stuff like that, sometimes the spray can get the O2 sensor on some setups.
I learned that in my Electronic Diagnosis class a while back. The instructor even demonstrated it for proof. -Jeremy |
06-25-2005, 11:44 PM | #23 | |
Happy to be here
To answer the original question I have used it for years and never had a problem. When I go to a show, I use it under my hood on almost everything that isn't chrome....
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-25-2005 at 11:45 PM. |
06-26-2005, 02:40 AM | #24 | |
-Jeremy |
06-26-2005, 03:08 AM | #25 | |
Like I've said before I'm not fond of the stuff and I could see it possibly baking the insulation on the wires (maybe) but it won't affect the O2 sensor.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc Last edited by 68LSS1; 06-26-2005 at 03:10 AM. |
