94-96 Impala SS Rear axle
has anyone ever thought of using one? If it is the correct width. you have limited slip(i think) and disc brakes all with 5 on 5 bolt pattern. for that matter just about any caprice cop car rear axle would work as long as it had the 9c1 (police) package. just remove the impala mounting brackets and weld on some saddles from early classic.
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
68cst_ss490
my boss has a old cop car with rear discs.
wonder if he'd notice it being gone.......... ![]()
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
![]() Join Date: Aug 2001
Anyone have the meausements from one?
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
![]() Join Date: Jul 2000
I have a 96 SS, will post measurements this weekend.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
PROJECT LO-LYF
I had a 95 ss about 2 years ago and put air bags on it. I still have the stock springs and shocks if anyone is interested.
Saving 1 truck at a time!
Sure...will the springs fit my truck? Are they coiled on both ends? Where are you located?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
PROJECT LO-LYF
To be honest, I will have to dig them out of the attack in the garage to see is if they are coiled at both ends, but I will check it out tomorrow. I am in Missouri. If you want them, 20 bucs plus shipping. let me know
96 Impala SS axle width is 62.91 inches the ratio is 3:08 it is limited slip (posi traction) with disc brakes it has sway bar also. I believe some of the police packages have discs without limited slip. Police package with disc and limited slip codes 2LZ and 2LX also two ratios 3:08 and 3:23.
#10 | |
Another dumb question - what is the measurement on a stock axle?
The measurement is from outside surface of one axle wheel mounting flange to the outside surface of the other. The measurement on my short stepside is 60.85 inches from outside surface of flange to flange. The fleetside trucks will be a little wider.
Born Psycho
![]() Join Date: Feb 2001
another killer rear axle for you 2wd guys is a SS454 truck, it doesnt have disc brakes but it is a 14 bolt semi-floater with 5 lug and takes very little modification to bolt into a 67-72 leaf spring 2wd. they came stock with 3.73s and limited slip too.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
