08-18-2005, 02:59 PM | #1 |
On the road
New headliner, Thanks HuggerCST and Bisquick65
Thanks Bisquik65 and HuggerCST. Got the headliner from Erick (Bisquik) and the trim from Wynne (Hugger) I got it put in yesterday, I think it looks good. Thanks for the deals guys,
Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 08-18-2005 at 04:56 PM. |
08-18-2005, 03:04 PM | #2 |
Tightwad
Looks sweet!!!!!!!!!!!!!!!!! Did ya have a head liner in it already?
08-18-2005, 03:04 PM | #3 |
Pics
What about pics of the whole truck, you dog
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear Last edited by fade94; 08-18-2005 at 03:04 PM. |
08-18-2005, 03:10 PM | #4 |
Tightwad
Yeah no joke that would be nice!!!!!
08-18-2005, 03:50 PM | #5 |
On the road
No Eric it did not have a headliner but I had to have one. It gets rid of the tin can sound inside. OK guys here are a few new ones of the truck, they ain't the greatest pictures though. I put a fresh 454 in it when I was home from work last time. It is bored 30 over, LS-6 style TRW forged pistons (10 to1 comp)has a steel crank, truck rods w/ ARP bolts. A nice little speed pro cam with only about 520 lift. 781 heads that I did a 3 angle valve job on (I have a valve grinding machine) I picked up a old Torker intake (the one where the carb sits crooked) at the swap meet as well as headers. I built a new exhaust system with aluminized mandrel bent elbows and tubing from JC Whitney and Summit turbos (I posted pics on your thread Eric). I have a old 850 double pumper on it. I found a decent set of the old factory chrome valve covers at the swap meet. It runs hard but is mild enough to run the AC in traffic. I built a fresh 400 turbo and I did a home brewed shift kit for it with the same mods B&M does to them on the direct clutch and stuff. It bangs pretty good. I got another tach dash at the swap meet and restored it and got it in. I had most of the bracket and pullys but thanks to HuggerCST (Wynne) I was able to get the right power steering setup and clamshell type motor mounts and the big block fan shroud and stuff. He has helped me a lot with the truck. I also have the correct 72 only upper alternator bracket on it. The big block is fun, I have not had one in several years and it brings back a lot of memories. It has brutal torque and will annihilate the rear tires in 1st and second gear....It's a blast. I bought the buckets and console form Frank (PIckMup) off here about a year ago.
Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
08-18-2005, 03:56 PM | #6 |
On the road
A couple more
08-18-2005, 03:58 PM | #7 |
Tightwad
Now thats what ya call a good looking Louisiana truck!!!!!!!!! I know i have asked before what size are the rims and tires?
08-18-2005, 04:03 PM | #8 |
See, I knew he was a dog....
DAMN NICE TRUCK...
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
08-18-2005, 04:07 PM | #9 |
On the road
Thanks Eric,
They are 245-60 15's on the front on 7" rims and 275-60 15's on the back on 8" rims. When I first did the drop and picked out the wheel tire combo was when Mike Clark the owner of Early Classic enterprises built that red and white 72 in Chevy truck magazine, about 97 or 98. I used the exact combo he used. If you go to the ECE web sight, check out "this old truck". That was the one I fell in love with. I patterned mine after his (wheels and all) and bought his kit and stuff to lower it. Mike
08-18-2005, 04:15 PM | #10 |
Tightwad
Mike, you have been a big help on alot of things, thanks for being a very good board member. We will have to get together sometime later on after i get mine back together. Thanks again and keep up the good work...
eric |
08-18-2005, 05:08 PM | #11 |
On the road
Thanks for the kind words guys. Eric, Oberlin is not that far away, I bet you could drive it in about an hour and a half. I have lots of parts and parts trucks so come check it out sometime. we'll take a spin, there are several board members here in town and all have nice trucks.
Mike.
08-18-2005, 06:04 PM | #12 |
[QUOTE=GSFMECH]Thanks Bisquik65 and HuggerCST. Got the headliner from Erick (Bisquik) and the trim from Wynne (Hugger) I got it put in yesterday
Its looks much better in your truck then in my parts building hanging on the wall for the last 15 years....I had that headliner that long.... I save stuff...67-72 truck addict i guess? Thanks for the smooth deal..Erick |
08-18-2005, 08:00 PM | #13 |
Dang Mike! You're making me Jealous with those pics. Would you guys believe that this is an unrestored truck? Hey Mike, why don't you bring it up when you come saturday & take me for a ride? That would be cool, but it would cost you a fortune in gas, (and would make me want a big block) so I'll take a raincheck. Man, I need to get to work on mine.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
08-18-2005, 09:17 PM | #14 |
its all about the +6 inches
That thing is as close to perfect as one can get IMO...perfect stance, perfect rims, alwsome paint color selection, a big block...who can argue?
That is a friggen nice truck there. |
08-18-2005, 09:30 PM | #15 |
67-72 Addict!
Andy is dead on the money!. SWEEEET truck.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-18-2005, 09:38 PM | #16 |
YA YA
damn mike, I think I wet myself.
Jimbo '72 SWB - 350 (frame-off resto in progress - donations accepted) '04 Chevy Avalanche '03 Cadillac CTS (wife's ride) Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707 |
08-18-2005, 10:22 PM | #17 |
The start of the $ pit!
What did it take?
I was thinking about adding one to the 68. How hard was the project? What all did you have to do?
08-18-2005, 11:36 PM | #18 |
Too many projects
Nice truck.
Jim '55 Chevrolet Pickup '56 Chevrolet Belair '04 Chevrolet Astro '95 Chevrolet Blazer |
08-18-2005, 11:54 PM | #19 |
On the road
Thanks yall! Wynne I would bring it but 3 of us are coming and little brother would have to ride in the back( that's the only downside to having bucket seats). I doubt I could get Kevin (65Streetcruiser) to ride in the bed so I guess we will have to come in the Z-71. The gas mileage did go down with the Big Block though, but who cares when you're frying tires huh. There were a lot of board guys that helped make this thing happen, yall know who you are and I appreciate all you guys have done. One of these days maybe we can have a board meet "down south style", pop a few tops and shoot the bull about it. Thanks again for all the compliments.
Mike
08-19-2005, 04:38 AM | #20 |
Looks good and they do help deaden the sound in the cab. I wouldn't be without one.
