Old 09-11-2005, 01:13 AM   #26
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Is that a factory Sunshell? That is the weak leagth in a factory 700R4...
Check out...
www.700r4.com also know as bowtieoverdrives.com
They have alot of good info and excellent parts for sale.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 09-11-2005, 04:26 AM   #27
4x4Poet
That's some impressive twist on the what looks like the TQ housing! (I'm no fan of autos and even less knowledgeable about them)
But, in line with masterbeavis' comments, I've often read on forums like this one that the 4L80Es are much stronger than even built 700Rs. And built 4L80Es can take some serious abuse. Might be worth it in the long run to save up to go heavier duty so you can forget about tranny troubles for a while. Maybe a long while if you don't try to show off to '05 Stangs.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 09-11-2005, 05:49 PM   #28
72MARIO
72MARIO's Avatar
Can I run a 4L80E behind a carbed motor ? Anyone know if a 94 astro would have that tranny ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-11-2005, 05:52 PM   #29
alf1096
alf1096's Avatar
Well I have never seen the inside of a tranny before thanks for voluntering the pics
sorry about the loss thats it going to be no fun to fix
1970 Short Stepside----Process of Restoring
1983 1/2 Silverado
alf1096 is offline   Reply With Quote
Old 09-11-2005, 05:54 PM   #30
cableguy0
94 astro wouldnt have a 4l80e. its a bit expensive to get the standalone electronics to work with a carbed motor as well.you would need to find a 3/4 ton or heavier truck to get a 4l80e. then get a standalone control unit from tci which is 1200 bucks on its own.i have had two seperate ones that refused to communicate with the laptop.real pita
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-11-2005, 05:58 PM   #31
71-longbed
Its Magically Delicious
71-longbed's Avatar
Thats some awful carnage there !!!... glad no one was hurt
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 09-11-2005, 06:53 PM   #32
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
cableguy is right. The 4L80E is an outstanding tranny, however it makes the work doing up a 700R4 look like fun. You can get a stand alone harness and computer out of a certian year (I have NFC WHAT year) diesel truck/burb...but they are far and few between. (When was the last time you saw a 6.2/6.5 truck in the bone yard...and what was left on it?)
Old 09-11-2005, 06:56 PM   #33
cableguy0
but if you were to find a diesel computer it has to be completely reprogrammed for the gas engine more cash there
Old 09-11-2005, 07:12 PM   #34
Longhorn Man
ahhh, I did not know that. Thanks
Old 09-11-2005, 07:55 PM   #35
acloco
94 Astro will have a 4L60E.
About the only vehicles with 4L80E's....something with a diesel or a big block, 1 ton, or special ordered.
The E part of 4L80E is what is the kicker....everything is controlled electronically....upshift, line pressure, blah, blah, blah....
Why not build Turbo 400 and use a switch pitch torque converter?
acloco is offline   Reply With Quote
Old 09-11-2005, 09:50 PM   #36
68C15
blood type; Retumbo
68C15's Avatar
that is possibly the worst carnage i have ever seen. makes me wonder if the TV cable was adjusted correctly. these things can build LOTS of pressure and in the one pic it looks like she split at the end of the input shaft.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-11-2005, 10:37 PM   #37
llegos
that blows(no pun intended)
-Steve
llegos is offline   Reply With Quote
Old 09-11-2005, 10:51 PM   #38
1969 GMC
1969 GMC's Avatar
The 4L80E was first used in '91 IIRC, and in that year the 6.2 diesel was still used, which did NOT have a computer. I believe it was used for a few years after that as well. These should work with a carb'd gasser, but they won't be common.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-12-2005, 12:43 AM   #39
cableguy0
it will work after it is reprogrammed the diesel has totally different shift points than a gas motor
Old 09-12-2005, 01:31 AM   #40
71RestoRod
71RestoRod's Avatar
Sheesh… talk about no way to limp home. I believe the technical term for that is “total spontaneous disassembly”.
700R4 or otherwise…. that just ain’t right. I’d be tempted to lay it all out in front of the builders shop door and guard the pile like a rabid dog until I had a check in hand.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 09-12-2005, 02:18 AM   #41
Fred T
Cantankerous Geezer
Fred T's Avatar
Since you bent the shaft, I would suggest checking the pinion bearing.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-12-2005, 07:18 AM   #42
70c10
67-72 Addict!
70c10's Avatar
Sorry to hear that Mario. Glad nobody got hurt.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-12-2005, 12:01 PM   #43
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Damn that is the biggest tranny gernade I have ever seen...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-12-2005, 12:33 PM   #44
86swb
Born a Chevy Man
86swb's Avatar
Sorry to hear about your mishap. Glad your dog was not hurt. Part could have come through the floor. What year tranny was it. I have heard pre '87 and not as good as '87 on.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 09-12-2005, 02:18 PM   #45
classicchev
classicchev's Avatar
COOL, all from a stocker. Duece better put a block under the pedal, or we will have more carnage in Canada.
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 09-12-2005, 02:57 PM   #46
chevy71super
I'm surprised the guy with the 05 Mustang didn't file a claim against your insurance company. To be honest if someone's car shedded parts in front of my car and damaged it I would be asking for the name of their insurer.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 09-12-2005, 04:12 PM   #47
Russell
Professional Grade
Russell's Avatar
That my friends, is why I'll pay the extra dough up front to get a 4l80e for my GMC. You save that money on the first tranny explosion that you prevented.
I plan to use the diesel shifter, I know a few guys who will re-program one for me. They are relatively simple to re-program as far as I am aware. They apparantly use a prom similar to any older GM ECM, and its just a matter of setting the shift table up for a gasoline engine rather than a diesel engine, which means that a guy has to do a couple of different tables, depending on the TPS, VSS, etc.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-12-2005, 04:44 PM   #48
68gmcdually
68gmcdually's Avatar
I'll have to keep my eyes out in the Uxbridge area for an oil slick. At least you had fun with it for most of the summer. Good luck on the repairs.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 09-12-2005, 05:06 PM   #49
72MARIO
72MARIO's Avatar
You will see the puddle for sure. Hwy 48 and Davis drive. Go west towards newmarket on Davis Drive and about 40 feet after the lights there is a huge puddle of fluid. I marked my spot.
I went to the shop today and showed the tranny shop the pitcures of the damage. I brought the dented drive shaft and a milk crate full of parts I picked up off the road and the tranny. He is not going to take care of anything but rebuild the tranny and in his words
"it will be cheep"
I hope when I show up it's Free. I still need to gater a god chunk of cash just to get the tranny back in the truck.
2005 TAHOE DD
Old 09-12-2005, 05:20 PM   #50
cableguy0
he should pay for everything. that case had to be cracked when he built the unit.
