nsane68 or anyone with air bags Help!
So i have this new idea instead of doing a crossmember drop to cut up where my top bag mount is now about 2 inches or a little less.Strait across the. Weld a flat piece of steel across where i just made the cut with about 3/4" tab all the way around. So you can bolt the bag mount up. Then cut a piece of pipe bout 1 inch or so or less at the angle you need to make your spring square at ride hieght. Weld the pipe to another piece of flat steel and bolt it up to the where you cut the crossmember. What this will do is sit the crossmember all the way on the ground with 17's wheels. Right now my front sit about an inch off the ground. Then I can use my sway bar again because it wont let the bags collapse all the way. Hit the existing crossmember. Do you guy think this would work and not mess up the steering or ride.
TTT help
aka Crusher, Crushergmc
Maybe if you explained it in more detail? I'm not sure I get what you are trying to do (it may just be me). Write what your trying to do step by step, then read it a few times to make sure it's exactly right.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
Thanks- 70jimmy kind of rushed the whole thing- I will try and take pics this weekend and explain it more.
SLICER AND DICIER
I kinda understand, but pics would help alot. Also if you have a scanner draw a quick sketch of you idea and post that. I would be glad to help, I just don't Quite follow. hehe
01 Tahoe 22's 2/4 drop and tv's ![]() 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
