Old 08-26-2002, 03:20 PM   #1
JoetheMobster
Listening since '86
JoetheMobster's Avatar
Question Do I have the right part?
Hey folks, this message is related to the post I made earlier about my center support bearing.
I am wondering if this is the right part, as the one on my truck is completely destroyed!
This one cost me $27.95Cdn
Oh, and it says SKF part# HB206-FF
2007 Saturn Aura - hey it WAS a GM product
JoetheMobster is offline   Reply With Quote
Old 08-26-2002, 03:34 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
well, it depends...
there are two different styles, the one you show is the light duty 3 speed and th350 one,
there is a heavy duty one thats bigger and bolts across the crossmember instead of inline with it and i ave a pic, but its on my hard drive so id have to mail it to you, was mainly used on the big 4 speed models and on 73-up 3/4 and 1 ton trucks
you wil have to get under your truck and see which yours has
good luck
Fast68Chevy is offline   Reply With Quote
Old 08-26-2002, 03:40 PM   #3
COBALT
COBALT's Avatar
Yeah, that's the one you need.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-26-2002, 03:42 PM   #4
JoetheMobster
Listening since '86
I took a second look, not relying on my memory....it's correct! Sometimes I wonder about myself!! hahahaha
Old 08-26-2002, 03:43 PM   #5
JoetheMobster
Listening since '86
thanks again, new69owner, I didn't see your post when I posted the second time.
Old 08-26-2002, 03:51 PM   #6
COBALT
COBALT's Avatar
Again, no prob.
I mentioned in the other thread about you taking a picture of the ruined one on your truck. Can you do that? I'm curious after you said the bearing looked like it "dissapeared". That's got me wondering...
Seattle, WA.
Old 08-26-2002, 04:48 PM   #7
breeh
Recovering 67-72 Addict
breeh's Avatar
Fast, you can attach pics from your harddrive. Just go to the bottom of the screen where it says attach and then use browse to find your file. Voila!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 08-26-2002, 11:59 PM   #8
RipMeyer
RipMeyer's Avatar
Doh, that looks like the cheapo from india! where is it made?
RipMeyer is offline   Reply With Quote
Old 08-27-2002, 01:15 AM   #9
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
I'm not sure where SKF bearings are made, but we use alot of them at work and they don't usually skimp on the quality of the parts they order since they are going on $500,000+ machines.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-27-2002, 01:44 AM   #10
slam33
slam33's Avatar
There is a poly one available, I think energy suspention makes is
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 08-31-2002, 08:06 PM   #11
JoetheMobster
Listening since '86
RipMeyer:
The part is made here in good 'ol Canada.
If I'm not mistaken, SKF bearings are made in Canada as well.
BTW, as mentioned in my other post, the old bearing seized completely solid with rust!! Wouldn't budge an inch! Naturally it ripped the rubber all to hell, and broke the outer metal support.
Old 08-31-2002, 09:13 PM   #12
Yellow Cheyenne
Joethemobster,
Just curious. Does your pickup have coil or leaf rear spring suspension?
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 08-31-2002, 10:54 PM   #13
JoetheMobster
Listening since '86
It has coils all the way around.
Old 08-31-2002, 11:14 PM   #14
bigjimzlll
bigjimzlll's Avatar
that looks nuttin like mine..i must have that heavy duty one amd its a pain ti the arse to get in and out
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-01-2002, 03:48 PM   #15
Yellow Cheyenne
That's what I would have guessed. The bearing in the photo that you posted should be correct for yours. Seems most GMC's have leaf rear suspension and if it did, probably would have had a different bearing.
Good luck with the replacement.
'70 Olds Rallye 350
