11-15-2005, 02:54 PM | #1 |
You Are Not Forgotten
Vintage Air install firewall pics
Hey people, I have just received my vintage air system and I am looking for pictures of shaved firewalls with this setup. I have seen quite a few of them on this site but can't seem to find them again. What I remember was a finished product with a neat metal finish, not with the plastic supplied by VA. Any & all help is greatly appreciated. A 72 chevy is the project.
If you don't know where you are going, any road will take you there! Last edited by jcarlar1; 11-15-2005 at 02:55 PM. |
11-15-2005, 04:46 PM | #2 |
Re: Vintage Air install firewall pics
No one has any pics of finished firewall after VA a/c install???
If you don't know where you are going, any road will take you there! |
11-15-2005, 04:51 PM | #3 |
67 is sold
Should be a good thread
11-15-2005, 05:25 PM | #4 |
yea, will send a couple when I get home--however I do have Old Air
11-15-2005, 05:45 PM | #5 |
Anything for ideas would be greatly appreciated
11-15-2005, 06:33 PM | #6 |
Keep On Truckin'
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
11-15-2005, 06:48 PM | #7 |
Questionable
Link to FirstGen's install (can't tell you how many times I've posted this)
http://67-72chevytrucks.com/vboard/s...75#post1310375
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-15-2005, 07:08 PM | #8 |
This is Old Air in my 67.
11-15-2005, 07:43 PM | #9 |
No AC installed yet, but you can see the shaving job I did on the firewall in this pic here, from Vtblazer's thread:
I cut out both of the non-ac holes with their support ribbing and welded in 16 guage sheet steel. I also did it for the fan duct hole. I plan to run the hoses through the bottom of the cab instead of that spot in the FW. Last edited by FormerMember; 11-15-2005 at 07:44 PM. |
11-15-2005, 08:55 PM | #10 |
For Mocwon; In your picture you have the hookup I am interested in, is it a custom unit ,factory, or did you fabricate it?
11-15-2005, 09:14 PM | #11 | |
no brain no headache
1996 GMC Sierra z71 1970 SWB 2wd (project) |
11-15-2005, 09:28 PM | #12 |
67 is sold
Any pics of the AC hoses running down as low as they can?
11-15-2005, 09:51 PM | #13 | |
11-15-2005, 11:22 PM | #14 | |
Keep On Truckin'
11-15-2005, 11:31 PM | #15 | |
Keep On Truckin'
11-16-2005, 10:59 AM | #16 |
If you purchased the Sure-Fit system, it is designed as a bolt in kit with the lines running through the firewall plate. If you want a smooth firewall, a universal kit like mocwon is using OR modify your evaporator and install a coil with the lines running parallel to the firewall. Which option you choose will also depend on what control panel you want to use - OEM controls, you will need to have your SFK evaporator modified. Universal system would require the use of a VA universal control panel mounted into your dash.
Call Vintage Air if you have any questions - we can walk through you options with you. 1.800.862.6658 Mark |
11-16-2005, 12:09 PM | #17 | |
Questionable
http://satellitehead.com/images/68ch...lems%20008.jpg I don't see that on yours ?
11-16-2005, 01:28 PM | #18 | |
11-16-2005, 03:03 PM | #19 |
Questionable
I am looking, I just don't see that lip on yours. I see the hump (or setback or whatever) but not the lip. It's eating me up what to do with mine
11-16-2005, 03:40 PM | #20 |
Saving one 72 at a time!!
Jcarlar1,
I will shoot some pis tonight, what I did was, Placed a thin paper sheet over the whole opening and traced it, then I cut it out of sheet metal and tacked in in place. I finished it with brass and sanded it smooth, for the hole that the line came through, I took a peice of 3" Iron pipe about 2.5" long and welded it in place and ran the lines through the front, I cut the holes out of the cap to let them go through. It looks really good, but it is a lot of work, when I did this I had the cab off and on a stand, depending on what stage your in, this may not be an option. It seems like the last time I talked to Mike at Vintage Air, when I ordered my system for my Chevelle, he said that they were working on some new blanks for this area. He said they were looking for someone to make some billit aluminum plates..But I don't know where that ended up. I would call up there and see if they have anything, its worth the phone call before I would do all this fabricating. TS |
11-16-2005, 05:57 PM | #21 | |
11-16-2005, 06:24 PM | #22 |
TS looking forward to seeing your pics, I have a bare cab off the frame at the present. I called VA and the bulkhead adapters will not work with the sure-fit package I bought so they say. I don't mind the work if it looks good, thanks, John
11-17-2005, 09:12 AM | #23 |
Ttt
