11-27-2005, 02:25 AM | #1 |
Subs under the seat
If any of you ever put your subs under your seat could you please post some dimensions and pictures? I would really appreciat it.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
11-27-2005, 12:45 PM | #2 |
Re: Subs under the seat
Hey man I explored that option at length! There isn't room under there for a nice install of any sub that i found. there is a rod that runs side to side. Also there wasn't enough room under there for even an 8 in sub with the magnet in a custom box. Let alone enough volume in the box to support it. I decided to buy some really high quality componet speakers from boston accoustics to compensate for the lack of subs, didn't install them. I got rearended and now i want to sell the truck. The only place i found to hold the 6" mids was a custom center console....had to make it. I already had 5 1/4's in the doors so they might go in your doors if there's a vacancy. Nice sound in these old trucks just depends on how custom your project is getting. I have a lot of ideas for my next one.
1969 K20 not running, complete but rusty with wrecker boom and push bumper 1969 GMC C20 un-molested rust free original paint "a 4 eyed girl named 'Tina" 1971 Chev K20 4X4 Box Delete Commercial Truck Flatbed "Choose a job you love, and you will never have to work a day in your life." Confucius |
11-27-2005, 02:49 PM | #3 |
How many people drive your truck and need to move the seat? If it never gets moved just get rid of the rod or cable that runs side to side and you can fit for sure a pair of shallow 8's or 10's down there. I think LongNlow72 has pics of his setup with a pair of JL 10w0's and an amp in the middle.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
11-27-2005, 03:18 PM | #4 |
pioneer make s a 3.??/ inch deep 12 inch sub. i had one behind my seat.
http://www.pioneerelectronics.com/pn...400838,00.html |
11-28-2005, 03:57 PM | #5 |
graphic designer
blaupunkt makes super shallow subs - the overdrive series. also, i had a kicker solobaric 8" in a factory wegde box that fit under the pass side. i did cut the cable and attachment point, but i never move my seat, either. you still can move the seat by pressing in the tab on the pass side and using the lever for the driver side. they just no longer work together. my phoenix gold amp sat on the hump hear the gas tank. worked awesome! wish it had not gotten stolen...
if you have one of the earlier seats that are foam only, you may not have room, but my 72 seat with springs worked, the springs sat on the speaker grill, but it worked...and rocked! just measure front and back height, length and width and check with local stereo shops for a wedge box that matches your dimentions. might have to jack up the front of the seat with a washer or two... |
11-28-2005, 04:17 PM | #6 |
Questionable
Google for low profile subwoofer and you'll find a slew of them.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-28-2005, 04:20 PM | #7 |
LAIDOUT
I ran a pair of MTX 8" subs in the MTX boxes under my seat, they fit fine after I shimmed the seat up about 1.5". I did have to undo the seat adjustment rod though. Then when the speakers finally crapped out, I removed them and reconnected the rod.
11-28-2005, 06:38 PM | #8 |
There is more room under bucket seats than bench. I have about 7" height so Im making a box for 8" kickers...
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
11-28-2005, 09:16 PM | #9 |
PROJECT 7DEUCE
Somebody on the board had a pretty nice bass tube type set-up in the passenger side corrner of his/her truck (gone2bad) I think may have had it??
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-28-2005, 09:21 PM | #10 |
im looking to get some blaupunkt 2.something" subs and if they done work behind the seat, ill just throw them under ethere
-Steve |
11-28-2005, 10:40 PM | #11 |
i explored the under the seat options, i used to have pics of some setups but i ended up going with 2 12" PIONEER premier the thin series shown above. problem is the seats eat most of the bass. thick ass lincoln navigator seats press up against the subs so it absorbs the bass or alot of it at least
70 longbed 496/th400/Ford 9" |
11-28-2005, 11:14 PM | #12 |
Is there more room under the seats than behind them?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
11-28-2005, 11:50 PM | #13 |
Im not big into car audio I just want something to play my rock and metal louder. So I was thinking of either 2-10's or 1-10 and running my two 6x9's in my door off the amp and getting two tweater for my dash and running them off the deck or maybe the amp.
How do those bass tubes sound? What is a good brand for them? Do you just buy the tube and add any 8 in sub?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo Last edited by BowTieMan; 11-28-2005 at 11:53 PM. |
11-28-2005, 11:54 PM | #14 |
Here are a few pictures I allready have.
11-29-2005, 12:16 AM | #15 |
What about one of these 8's under the dash like this? Or two under the seat?
http://shop4.outpost.com/product/432...H:MAIN_RSLT_PG
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo Last edited by BowTieMan; 11-29-2005 at 12:18 AM. |
11-29-2005, 12:31 AM | #16 |
BowTieMan, can you remember who did that bass tube in the corner like that? It looks like a bazooka bass tube, and I was just wondering if it was a 6" or 8" that they used, and how it sounds off of how much power.
11-29-2005, 12:38 AM | #17 |
I really wish at this time I could remeber. I thought it was an 8 and at the time he didn't try it yet, but this was a while ago so maybe he will see this and post some more info.
11-29-2005, 02:04 AM | #18 |
bowtie man, i am really lost on whats going on in the kicker sub install....want to explain?lol
-Steve |
11-29-2005, 05:45 PM | #19 |
The kicker sub install is two tens in one big box that has them facing up toward the seat. The way he took the second and thrid picture make it confusing.
11-30-2005, 12:21 AM | #20 |
good to know there's a way to mount em under the seat. I took one look under there and thought no way....<---feels stupid.
11-30-2005, 12:28 AM | #21 |
yeah the under the seat sub boxes were a bit of a challenge, the only thing I had to remove was the wire goin under the seat to slide it forward and back, it still moves just takes 2 people but how often do most poeple move the seat?
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done... |
11-30-2005, 01:32 AM | #22 |
i want to thow some under the seat, i am just worried about my a$$ vibrating...anyone have trouble with that?lol
-Steve Last edited by llegos; 11-30-2005 at 01:33 AM. |
11-30-2005, 04:51 AM | #23 |
A day should have 30 hours.
i just put my 2-10 in the doors had to do some insolating but worked great until it got stolen now if got to battle with my insurance company (they dont wanna pay)
anyways my 2 cents |
11-30-2005, 12:22 PM | #24 |
I really like that corner tube design, wish we knew who did it. It really looks like the best option as most of the bass under a seat will get muffled anyway (that is if you care about quality).
72 Chevy Short Bed Fleet: 350/TH350 - Sold - Now trying to sell the parts that I have left over. _______________________ 2006 VW GTI |
11-30-2005, 03:24 PM | #25 |
Self-proclaimed LED man
I have two walmart cheapie subs under my seat. I made the boxes out of MDF in woodshop class (I got an "A" on it so dont laugh ). In my opinion, they are way too small for the subs. I think they came out to like less than 1/3 of a cubic foot and i really needed about 3/4 of a cubic foot of space for these subs. I cant remember though. They dont sound that bad. And yes they do give you quite a butt massage when you turn them up Now that they are painted black, and the console is color matched to the dash, to someone who doesnt know anything about these trucks, it almost looks factory. I mounted an amplifier under there too.
