Collector of Projects
Who has Impala SS rear disc brakes ??
I remember seeing pics on the board, but I can't remember who did this..
![]() Join Date: Jun 2002
Re: Who has Impala SS rear disc brakes ??
This is the only one I remember, hope it's right.
Rg http://67-72chevytrucks.com/vboard/s...d.php?t=108923
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
Those are the pics I remember.... I am addeng them to this post... I will PM 383 Stroker to find out more details... Here's a quote from his original post."There mid 90's Impala caliper and rotor with a custom made backing plate."
Junior Member
![]() Join Date: Jan 2005
Are those calipers the same PBR calipers found on Camaros and Corvettes?
![]() Join Date: Mar 2004
i'm very interested in hearing more about this "custom backing plate" as i'd rather use the ss calipers rather than the wimpy s-10 ones.
ondrew |
According to CarPArts.com the corvette and the camaro have a different part number then the Impala SS ... Now this is not 100% but it would lead me to believe that they are different...
Here are some pictures of the backing plate I made. I also attached a drawing of the bracket with specs. This setup does not have a E-Brake because it's built into the stock backing plate. If you want a E-brake you can use the Camaro caliper as it has the E-Brake built into it.
Did you have to modify the the axles or discs? What master cylinder are you using. It seems like most of the braking action with the stock brakes is in the front. Is there a noticeable difference in braking with the rear discs.
thank you for the extreemly valuble information. i will be using it.
ondrew |
well i'm working on it. there will be a slight delay since my rear end is completly disassembled but when i get these working properly i will explore the idea of selling them to the board.
![]() ondrew |
#12 | |
I've had a few people PM me about what master cylinder I'm running, so I will post some pictures of it.
Using a line lock for the parking brake?
The impala caliper brackets look like they will fit an old school 10B. I want a mechanical parking brake. Yours is a 12B, right? Last edited by FormerMember; 12-02-2005 at 10:20 PM. |
#15 | |
#16 |
Here's what I use my line lock for. Burnout Video
#17 |
OK, thats just wrong.....
wheres the rest of the video? I wanted to see you stomp that S10s ass :lol |
#18 | |
Here's the rest of the video. Racing S10 Video |
#19 |
Straight jacket required
JESUS!!!! I could watch those ALL day--Awesome!!
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
#20 |
I used camaro calipers and caprice on two of my trucks the swap was easy. [IMG]
#21 |
Vintage Evil
Are the caddy calipers the only one that have an ebrake?
#22 | |
Just Don't Stop!
![]() Join Date: Feb 2004
What year camaro calipers are these from and what thickness is the caliper? Thanks.
1968 C10 build in process TT LSA/6L90e/9" |
#23 |
The Caliper Is From A 96 Camaro And A Rotor From A Caprice.i Don't Know What Thickness Your Looking For On The Calipers
#24 | |
#25 |
TTT--need dimensions if possible of both brackets
