12-21-2005, 02:43 PM | #1 |
Senior Moment
Old Tools What is this ?
I recently came across a bunch of Old Tools. I dont know what the lone one is. Anybody Know ??
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
12-21-2005, 02:47 PM | #2 |
67 Shortstep
Re: Old Tools What is this ?
It looks to be circa 1700's....Early wood drill....the opening on the top was for a board (similar to a 2x4) to be inserted through it so that you could apply pressure to it by leaning into it with your chest.....
67 SWB Step 69 LWB CST 71 LWB 94 SWB Step 05 1500 Dodge P/U Adapt, Improvise, Overcome |
12-21-2005, 02:51 PM | #3 |
That would be my guess is a drill....though I can't provide the learned information my predicessor did.
12-21-2005, 02:52 PM | #4 |
Yeah it's a really old drill. My friend has one he still uses, very cool!
1959 GMC project |
12-21-2005, 03:37 PM | #5 |
Egg Beater......
Seriously though,I find it interesting that the teeth dont go all the way around the drive gear. Seems to be designed for a back and forth motion not a full rotary motion like a drill. Last edited by screamin_c102; 12-21-2005 at 03:42 PM. |
12-21-2005, 04:13 PM | #6 |
Still drivin' a Rat Rod
I can't say for sure,but it sure looks like a lot of work
Cool stuff to have though
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
12-21-2005, 05:32 PM | #7 |
If there are not 360 degrees of teeth on the main gear, indicating that the only use of the thing would be to make the shaft move in a back-and-forth rotation by a similar back-and-forth rotation of the crank handle, it almost looks like an old valve lapper. ... for lapping in valves into the cylinder head (or, in the case of a flat-head engine, into the engine block).
12-21-2005, 05:36 PM | #8 |
Try here www.papaswrench.com Papa will be able to tell you, in fact he is a member here to!
1999 GMC 2500--Natural Gas Powered baby! 2007 Chevrolet Tahoe Have you subscribed? Click here. Order your site t-shirts and apparel here! Last edited by smirch9; 12-21-2005 at 05:37 PM. |
12-21-2005, 06:01 PM | #9 |
Ob-Gyn Kenobi
It is indeed a drill. If you look closer, the flat section is recessed below the teeth, and there are 3 patches of teeth that look to be at 120 deg to eachother. It will go all the way around...after the last tooth passes on the top the first one on the other side is just coming into engagement. If you had to cut teeth with a file or whatever back in those days, would you not just cut only what you need and not all 360 deg?
Being smart is not necessarily being lazy.
'85 GMC Shortbox... I used to have a firm handle on life....then it broke off. Last edited by Opper77; 12-21-2005 at 06:01 PM. |
12-21-2005, 06:06 PM | #10 |
Good point, Opper. Its the little swivel attachment of the working end that makes me think its a valve lapping tool.
12-21-2005, 07:15 PM | #11 |
That is the original cordless drill.
12-21-2005, 07:17 PM | #12 |
Cool
12-21-2005, 07:20 PM | #13 |
Senior Moment
The teeth are in sections so as to make the bit go back and forth as you turn the handle. There's a gear at each end of the teeth and it only hits one set of teeth at a time makeing it change direction. the lapping tool has my vote so far.
Thanks for all the input.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 12-21-2005 at 07:21 PM. |
12-21-2005, 07:22 PM | #14 |
It looks like a tool we used to use to make rope. Maybe we were using an old drill to make rope, I was only 8 or 9 years old at the time so I really can't be sure.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-21-2005, 08:00 PM | #15 |
That was my thought, a rope winder.
Older than internal combustion engines is my guess. |
12-22-2005, 09:18 AM | #16 |
The consensus at my office is, IT IS A COTTER KEY REMOVER!!!!!!!!!!
12-23-2005, 11:25 AM | #17 |
As others stated... It's a valve lapping tool. The teeth are set up to use the handle in any one of three positions but in a back and forth motion. It looks like it might be missing the piece that sits on the valve... Here are a couple ones similar to it:
http://cgi.ebay.com/Valve-Lapping-To...QQcmdZViewItem
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
12-23-2005, 01:31 PM | #18 |
F.A.S.T. president
I think the guy who last did some daily driver body work for me uses these tools.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 10-05-2007 at 07:13 AM. |
12-23-2005, 01:51 PM | #19 |
Catchy title goes here..
1970 CST Short Wide papawswrench has a site dedicated to old tools also. Its a newer site that is growing, but there are some very helpful people over there also. http://papawswrench.com
i so missed smirchs post sorry for the double but its a good place to check out Last edited by Liz; 12-23-2005 at 01:52 PM. Reason: overlooked smirchs post somehow.. |
12-23-2005, 02:01 PM | #20 |
~Rest In Peace~
i saw the 3 stooges use it for mixing batter (knuck knuck knuck )
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex Last edited by fastwillie 696969; 12-23-2005 at 02:02 PM. |
12-23-2005, 02:06 PM | #21 | |
User #12137
12-23-2005, 04:52 PM | #22 | |
Running on empty
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver |
12-24-2005, 10:29 AM | #23 |
Sorry guys - I missed this post !
That is most likely a valve lapping tool , missing an attachment . It would alternate direction and lap the valve seat . There are some like it that were used as paint mixers in the old days also . Judging by the old carpenter tools in the picture , that would be my guess as to what it was used for by the owner . Definitely "old school " !
papawswrench Certified wrench hound ! Tool Talk Randomview PapawsImages https://www.flickr.com/photos/nhankamer/ |
12-24-2005, 01:57 PM | #24 |
Here is one on Ebay---
Link--http://cgi.ebay.com/Vintage-Antique-...QQcmdZViewItem
12-24-2005, 10:03 PM | #25 |
Looks like something used for the valve lapping, or the seats.
But they had something similiar to this not only for rope winding but for the wire cables...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
