Old 01-23-2006, 12:11 PM   #1
Lemield
Lemield's Avatar
Ammeter--boy am I stupid...
My Ammeter was not working....so I removed the instrument panel and replaced the ammeter gauge with an NOS one that I got off EvilBay. Put it all back together but the gauge still would not work. Decided to look in the shop manual and found the there are TWO fuses in the harness for the Ammeter???? Anyhow, replaced the fuse on the drivers side near headlight (18 guage black and white wire) and voila...Ammeter works.
Wish I had looked at shop manual before starting...Oh well...live and learn.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 01-23-2006, 12:14 PM   #2
farside847
farside847's Avatar
Re: Ammeter--boy am I stupid...
Dont worry, we have all been there. (remembering spending a good 3 hours trying to take off the ignition switch before finally reading in my manual how to do it)
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 01-23-2006, 12:36 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Good to hear you have admitted yourself to our club.
Now for the bad news. Your ammeter really isn't an ammeter. It's a voltmeter that measures the voltage difference between the alternator output and the battery input. The fuses protect the meter in case things get too out of whack. Now you can start feeling smarter again.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-23-2006, 04:29 PM   #4
Lemield
Lemield's Avatar
Thanks Fred....that is good to know!
Larry
Old 01-23-2006, 05:05 PM   #5
see ten
WTB this ad
see ten's Avatar
Ah Hell! The guy I got my C/10 from had the same problem. He replaced his gauge with a new one over 20 years ago and it still didn't work. I never took the time to try to track down the problem. After reading your post I went out and popped the hood, sure enough it was blown. Does anyone know what amp this fuse is? Mine was blown and apparently I broke the glass when I pulled the wiring apart. The fuse looks like it was very short. Can anyone tell me what I need to get it going again?
see ten is offline   Reply With Quote
Old 01-23-2006, 05:11 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
At the risk of sounding stupid myself.... where are there fuses under the hood of a 67-72???
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-23-2006, 05:18 PM   #7
see ten
WTB this ad
see ten's Avatar
On my 72 by the drivers side headlight there was a black wire with a white stripe. It had a fitting(?) made of rubber that seemed to be pressed together. The fuse was in that. It was obvious mine had been blown for some time but I broke the glass getting it out. Now I need to know what to replace it with.
Old 01-23-2006, 05:20 PM   #8
john
member #16
john's Avatar
see ten the fuses are 4 amp. John
john is offline   Reply With Quote
Old 01-23-2006, 06:10 PM   #9
see ten
WTB this ad
see ten's Avatar
Well I put a fuse in it and that didn't seem to help any. Oh well.
Old 01-23-2006, 06:16 PM   #10
john
member #16
john's Avatar
Did you find both fuses? The second one is located by junction block by batt. John
Old 01-23-2006, 06:50 PM   #11
see ten
WTB this ad
see ten's Avatar
AH-HA! That got it going again my friend! The guy I bought the truck from had owned it 27 years and said it didn't work the entire time he owned it. He even told me he had replaced the gauge with one from GM. I owe you a beer my friend!
Old 01-23-2006, 06:53 PM   #12
Yukon Jack
Yukon Jack's Avatar
This post is just another example of why this board rocks!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-23-2006, 07:06 PM   #13
72MARIO
72MARIO's Avatar
I got some fuses to check..... Only there under the dash in my truck now. With the shaved firewall all the wiring is tucked up under the dash this is going to be fun.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-24-2006, 02:39 PM   #14
Lemield
Lemield's Avatar
You already got it fixed but I think the fuse is an AGC4.
Larry
Old 01-24-2006, 04:01 PM   #15
Lemield
Lemield's Avatar
Finally my ignorance pays off! Usually, I get in deep doodoo when I'm stupid around the house....this time it actually helped people!
Larry
Old 01-24-2006, 08:02 PM   #16
Fatback
Fatback's Avatar
I found the one at the drivers side, but after years of being butchered up, I dont have one by the juntion block at all.
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Fatback is offline   Reply With Quote
