09-22-2002, 08:10 AM | #1 |
cab removal
Ok this is my first major rework, I want to remove the cab on a 67 fleetside what am I looking at as far as problems, and do I need anything special,
thanks the Rookie |
09-22-2002, 10:34 AM | #2 |
Seņor Member
It's usually pretty straightforward. You can take your front end off in one piece by yanking a handful of bolts. The things that have bitten me in the past are removing the actual cab mount bolts. These have a tendancy to rust up so taking them out sometimes means destroying them. Also be prepared to find more "damage" than you were expecting (rotten cab mounts, rust, etc.).
Good luck, Kenneth
09-22-2002, 11:41 AM | #3 |
Yeah I've already found out about rust thats why the cab has to be lited for welding and cleaning, it's a northeren truck so rust is no surprise, main thing with me is no place to work except the back yard in Flordia, all that sand and such this is gonna take awhile thanks for the reply mike
09-22-2002, 12:49 PM | #4 |
Cantankerous Geezer
Best thing to do before removing the cab is to lighten the load as much as possible. Remove doors, windshield, seat, gas tank, steering column. Then get 4 friends and some beer. While your friends lift the cab off the frame and set it on some blocks, you supervise and drink the beer! But if you only have 2 or 3 friends you will have to help with the lifting before drinking the beer.
Fred There is no such thing as too much cam...just not enough engine. |
09-23-2002, 07:35 PM | #5 |
thanks Fred plan to do some beer drinking yes majority of the work is of course on the bottom and the back side of the cab I'm wondering if I bit off more than I can chew nahhhhhh; thanks mike
09-23-2002, 08:17 PM | #6 |
Strap and shop crane works, replacing two of the three friends. You still need one to balance it while you are raising the lift and dragging it. It still leaves one hand free for the beer, however.
69 SWB LT1/4L60E www.classicplace.com |
09-23-2002, 09:44 PM | #7 |
thanks for the info on the crane and the friends working in the Flordia sand in my back yard is gonna get real tricky, no grage to work in, oh welll have a good one and thanks again; mike
