Old 09-22-2002, 11:13 PM   #1
chevynut
chevynut's Avatar
Rides rough - C20 Custom Camper w/no camper
I just took off the camper from my 3/4 with the Custom Camper option and does this thing ride rough. I don't think I could drive it this way. It is like the is no suspension in the ass end. It definitely drove a lot better with all they weight back there.
I am thinking about either putting new leaf springs of removing 1 or 2 of them.
Does anyone now if the 73-87 leaf will work in the 67-72 trucks with leafs? I think my brother has some 3/4 ton leafs from a 78.
Any other ideas on how to get some decent ride from the rear of this truck would be helpful.
Mike
1989 C1500 SWB Reg Cab
2003 Chevy Tahoe Z-71
70 Camaro RS/SS - 454
chevynut is offline   Reply With Quote
Old 09-22-2002, 11:24 PM   #2
Spoof
Spoof's Avatar
I had the same ride with my custom camper. It was only really smooth with a cord of wood in the back and then it drove like a dream. Sorry I cant help with a solution but you could try removing a leaf.
Is that a longhorn or does it just look long with the camper on?
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 09-22-2002, 11:25 PM   #3
Gee_Emm
I took a pair of leafs out of my custom camper 3/4 ton and it made a BIG difference. I took out the thicker one of them all. It was the bottom one was twice as thick as the rest.
Gee_Emm is offline   Reply With Quote
Old 09-23-2002, 12:00 PM   #4
Mike C
Mike C's Avatar
My truck drives nice with the 7500 gvw rear leafs. Get some good shocks first, makes a world of difference. The large lower leaf is the overload leaf designed to reinforce the spring pack when you have a heavy payload. The newer springs will not work as they are 2 1/2" wide vs. 2 1/4" (this is assuming 8' bed and 2 wheel drive. 4 wheel drive and Longhorns got 2 1/2" wide springs) Another option are the velvet ride shackles by BF goodrich if they make a 2 1/4" version. It is a small torsion spring that replaces the shackle and the truck rides on this until a certain weight is exceeded. Then theis assembly "locks" acting like a conventional shackle and using the truckis springs. I bought a 2500 series truck just for its payload capabilities. You don't want to have to change springs or modify your truck every time you want to carry any weight.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-23-2002, 12:07 PM   #5
Protrucks
I thought that all Longhorns had Coils did they make a Longhorn with Leafs
1967 Chevy 1/2 SWB (under construction)
1968 GMC (propane-under construction)
1969 GMC Flatbed (propane)
1970 3/4 LWB (propane)
1970 Stepside 402 (gasoline)
1971 GMC Burb
Protrucks is offline   Reply With Quote
Old 09-23-2002, 02:03 PM   #6
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
ALL longhorns had leafs, none had coils, coils were a 1/2 and 3/4 ton 2wd option(Chevy, standard GMC) except longhorns and ALL 1 tons are leafs
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 09-23-2002, 04:28 PM   #7
Gee_Emm
Wasnt it that GMC's had standard leafs with optional coils and Chev's had standard coils with optional leafs?
Old 09-23-2002, 07:07 PM   #8
hjalbert
cracker
hjalbert's Avatar
fairly certain gmcs came standard with leafs.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 09-23-2002, 08:39 PM   #9
72'BBGMCSGCC
I put the spare where it should be which helps hold the rear end down and put on Monroe Magnum shocks and she rides great.They cost about $130 for all 4.
72'BBGMCSGCC is offline   Reply With Quote
Old 09-23-2002, 09:03 PM   #10
dwaite72lnghrn
Be sure to air down the tires. With no load 35-40lbs in a 3/4 ton. It makes a big difference. If you go to a spring shop they might be able to put teflon or rubber pads at the end of the springs to let them move against each other easier.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 09-23-2002, 09:58 PM   #11
conman
removed springs
I took out two leafs on each side, but left the short helper spring in. It doesn't work until theres a load. It also lowered the rear end. And get a pair of good shocks. It rides great.
Fayette Alabama
conman is offline   Reply With Quote
