02-01-2006, 04:47 PM | #101 | |
WTB this ad
Re: Wheel/Tire Fitment Pictures & Info
02-14-2006, 09:55 PM | #102 |
Here is my pick. I'm old school and still like lots of rubber and 15" rims. These are 285-70-15"s on 10" rims( no rubbing Issues) Frt's are 255-70-15's on 8" rims
Truck Has 3" drop spindles with 2 in drop springs. Rear has a 4" drop spring with a 2" spacer. Better pics at www.classictruckworld.tenmagazines.com Go to gallerys,then1968, mine is the BCHN-68 gallery. |
02-15-2006, 12:19 PM | #103 |
I need help on finding a cowl hood and shaved tailgate for 72 chevy pickup
02-15-2006, 12:59 PM | #104 | |
Hot Rods For Life
Nice. I actaully like the size you have for the front for my rear wheels.
02-18-2006, 05:54 PM | #105 |
diggertodd
Kudos to Radman - the look you have achived is great - can you tell me what backspace you used for the front/back - thanks in advance
02-18-2006, 10:29 PM | #106 |
The rims and the cowl inducton hood were the first things i bought to start this project. The rims are american racings standard back spacing. It's been awhile but it is in the neigborhood of 4 or 4 1/4" back space frt and rear. What ever standard is from the company. the fronts should actually have about an extra 1/2" of back space as the tire just barely touches the inner wheel well on a hard bump. I have a frt.sway bar from a 86 suburban mounted up frt and the truck corners great.
thx for the great comments! ttyl Rick |
02-19-2006, 02:15 AM | #107 | |
02-19-2006, 02:21 AM | #108 |
I just read this thread . . ..... some good info to use before spending your hard earned $$.....
215/70-15 on 15x6.5" van ralleys w/a 2.5" spindle & 2.5" spring (cut stockers) on the front & 255/70-15 on 15x8" truck ralleys w/ air bags, 1.5" lowering blocks, adj panhard bar & relocated stock shock mounts out back. Rubs up front on the top of the inner fenderwells on big dips/bumps in the road @ speed . . .... never a problem @ any other time.
02-19-2006, 09:21 AM | #109 |
scoti; did you notch your frame and cut out your box floor to make it look this great?
02-19-2006, 11:24 AM | #110 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-19-2006 at 11:25 AM. |
02-19-2006, 11:45 AM | #111 |
its just $$$$$
3" spindle w/ cut springs(1 wrap), 5" drop springs in the rear.
20x8.5" Coys Rodder 5 wheels w/ 5" Backspacing (too much for the rear) 255/35 Falken tires. second pic is same drop with 255-70s on 8" truck rallys |
02-19-2006, 08:21 PM | #112 |
Bagged74: love the look of the ralleys over the billet jobs and rubber band tires. Sorry, I'm old school and love BIG rubber.
Bagged&scotti: Notice how the rear tire moves forward in the wheel well when these trucks get this low. The frts always look so centered. I didn't like the rear look, so i am in the process of building new rear arms with a 15 degree angle on the rear arm to get the pinion angle right again. I also moved the rear axle mounting point on the arms back 1" to get the rear tire centered in the wheel well. I will have the new frt bushings here mon or tues and will post a pic when done. |
02-20-2006, 12:45 AM | #113 | |
02-22-2006, 08:06 AM | #114 |
Howdy evryone Im new here.
295/50 15 on 15 X 10 ralleys with 4" back spacingon all 4 corners with NO rubbing issues lowered 2" up front and 3" in the back http://67-72chevytrucks.com/vboard/a...1&d=1140609791 Last edited by 2-BAD-72; 02-22-2006 at 08:12 AM. |
02-23-2006, 12:51 PM | #115 |
Psycho-billy Member
Anyone happen to have a picture of a lwb fleet with 2.5" front drop - 4" rear drop with 15x8 4" b.s. front and 15x10 5"b.s. rear?
I know it's a shot in the dark but.... I'm thinking thinking that I'd like to go that route with my '72.
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American (or Canadian). |
02-25-2006, 11:31 PM | #116 |
295/45 20's... no rubbing issues----yet...
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! |
03-05-2006, 02:46 PM | #117 |
i have just purchased 71c10.can anyone advise me why when veiwing the truck the front the wheels are 1inch offset to the body on the left hand side.front and rear.Nothing seems wrong with the front clip or the rear axle.The truck drives straight and true.Could it be that the body cab and buck has been located wrongley or is this not possible.The wheel pcd measures at 5inches not 4.75.Any information will be apreciated.The truck is in England.Thanks.
03-06-2006, 04:09 AM | #118 |
15x8 stock toyota wheels. unsure of tire size. freshly bought. will look sweet with a 2" front drop which is in the works. think i may stick with these toyota wheels as they look like a decent aftermarket wheel. what do you guys think? they fill the fenders well. may go with a taller tire to fill the fenders to my hearts content.
-justin- 70 chevy longbed: 350/th350 12 bolt project |
03-06-2006, 12:02 PM | #119 |
Happy Camper
1st pic 71 Custom Camper 3/4 ton. Eagle Alloys with Bridgstone duelers @ P265/70R16's Stock suspension
2nd pick '68 1/2 ton with stock suspension, unknown wheel maker. Tires front 245/75R16 and rear LT235/85R16
RIP El Jay! Love you brother! |
03-12-2006, 12:20 AM | #120 |
Active Member
We put 295/50's on the back.....245/60's on the front. all on 15x8 ralleys. finally got them all matched up and put on!
03-12-2006, 12:26 AM | #121 |
Active Member
15x7 chrome mod's on the 68
03-13-2006, 03:29 AM | #122 |
is it true that you should c-notch the frame for 4 inch or bigger drop. going 4/5 with 20's on 1971 2wd blazer. if c-notch is not needed
03-13-2006, 11:07 AM | #123 |
A few of us are running around with 6" and no notch. No problem here I have 2.5" of travel and it still rides nice.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-18-2006, 11:47 PM | #124 |
Here's my 69,ECE's 2 inch spindels w/ 4" spring, 6" springs out back. American Racing Torq-thrust 6's, 17x9.5 w/245/45 front and 265/50 rear on Fuzion tires . Backspacing is bout 5'' front and 3.5 at rear.
03-19-2006, 12:20 AM | #125 |
chevelito
wow...6/6 drop.....can't wait till the pic shows up.
jay
New deadline...when my son can drive. Aloha from Honolulu, HI |
