Can you Fit Subs???
Can you fit subwoofers in a 73 Chevy C20 regular Cab???
What box would i use? a standard truck sub box? any one have pics of any in their truck?? would be much appreciated!! |
Re: Can you Fit Subs???
here id a pic of what i did. i used http://www.73-87.com/7387garage/inte...peaker_box.htm as a refrance.
it cannot hold anything huge.. about a sub with a 5 1/2 inch mounting depth but its better than nothing,,,
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
so should be able to fit two 10's fairly easy? use that to make the box?
do you have a spec sheet on how you built your consol for the cd player?
Nothing special but works... well rather it worked(trucks off the road right now). Without the 6x9 boxes there I can have the seat all the way back but as it is there i have to have it 1 notch forward.
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
Hotwheels?
Building audiophile grade home speakers is another hobby of mine, and ive come to the conclusion that 1 or 2 10's behind the bench is pretty much the sweet spot. Any more is not gonna do any good. Its just bad box design. Now you can get into fancy custom setups, but not with a bench.
Another good investment is some tweeters in the pillars. A simple X-over will do wonders and you will have a pretty full range of sound with some 6 1/2's in the doors or 4" in the kick panels.
1978 Money Pit - CUSTOM DELUXE!!!! |
what kinda box is that, just a kenwood truck box? is it for any certain truck?
Be careful when choosing 10" subs though. I had intended to use a pair of 10W0s that I had around until I pulled one out of the box and discovered that it's about 5 feet deep! My Adire Koda is almost an inch shallower than my 10W0s. Since I want to keep my seat all the way back, I've got to be careful with subwoofer depth.
how bout like a 10" sony xplod anyone got one using?
I have a couple 12's in Q-Logic boxes.
They sound great, but the speakers aren't getting the air space they require. The boxes are big which requires the seat to be pushed forward 2-3 notches from all the way back. This moves you closer to the steering wheel. Too uncomfortable for most. When I get around to redoing the door speakers and maybe getting kick panels I am probably going to sell these boxes and get something smaller (10's) so I can get the seat pushed back more. I used to 10's behind the seat and the bass wasn't enough. I went to the 12's and I was happy. Now I want the space back and will settle for some 10's. The amp pictures show how you can mount smaller amps under the seats. There are dips under the seat that allow you to mount the amps there so they are not touching the bottom of the seat. Before I had an amp about twices as long as the Sony, without any problems. Whether you buy or build your own box I suggest you put the seat where you want it then take the measurements to determine the largest box/speaker setup you can fit in your space. Then go shopping. If you spend the money and get a really nice amp and subs you can get incredible sound from a small setup. You just have to pay more for quality. BTW I got that Sony Amp at Circuit City on close out. It was $199.99, but on close out I got it for $70.00. It was NIB, never opened. They had (4) of them. Its been a great amp, very dependable and decent power.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 03-21-2006 at 01:42 PM. |
#12 | |
#13 | |
ive had 3 or 4 defferent setups in my truck from 2 8's to 2 12 to 4 12's behind my bucket seats to 2 15s which i have in a console now, only draw back that i kinda regret is that i should have started with buckets along time ago because the ones i have are alot smaller than stock ones and i was able to run a little bit bigger box on the bottom for air space
4 12 box that i use to have ![]() bottom side of my console ill get a side shot once i get home ![]()
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
#15 |
You get what you pay for
![]() Join Date: Dec 1999
I'm no audiophile when it comes to car stereo but my system sounds great to me. I am old but I still love lots of bass. Always have. Maybe it's why my hearing is going away.
![]() As for the Sony Xplods, I have two 12's (my setup in the links posted by C-10volvo) and love them. I'm sure there's better ones out there but to me, they are perfect. They provide all the bass I would ever want to hear in a pickup.
Mike 1985 Chevy C-10 |
#16 | |
#17 |
Street Rod Restoration
![]() Join Date: Jan 2004
I'm fabricating the center consol as a reverse sub box. ans then some pod speakers for the doors (mb quart) as well as 6x8 mbs in the cab corners, but this requires a custom seat application.
Follow me on Instagram @ hot_rod_shop |
#18 |
Sb 400 club
yeah i hear that guys.The guy a bought my truck from put in all sorts of subs but removed the whole system when i bought it. so i have wiring for an amp a blowpunk head unit and a cheap set of 8's in a pre fab box. i have no speakers in the cab corners. This is my question i can't find 4x10's any were. were can i get them or is there a better way to put somthing in the cab corners. If so what?
pics ? thanks
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#19 |
i was goin to do a reverse console with the subs facin out but i like ppl wanderin what i got in my truck since all u feel is bass, in my corner im runnin memphis 6x9's and i bought the brackets at a swap meet for little of nothin sht i just recently clean out my shop since rita fecided to destroy it and i found 2 more sets of 6x9 corner brackets
#20 |
the green machine
i've got an audiobahn 10" sub that i was going to make a box for that fits over the tranny hump and faces at about a 45* angle to the seats. see if i could find some green carpet to match my interior and there ya go! what do you guys think?
1975 Silverado - 450 horse crate 383 stroker, 20" Centerlines, Flowmaster exhaust, Hooker headers, full MSD ignition & more... 2003 Suzuki TL1000R 1985 Kawasaki JS550 hull - project ski - WILL have - 650, footholds, custom paint, 4* bars, bilge setup, and more... My pictures |
#21 |
not too much but here is mine. 2 12's. sounds pretty good. only had to move the seat forward about an inch.
#22 |
how do subs sound in a truck? are they extra loud (if so good) since its in such a small area compared to a car....do you have any problems with rattling? dont really wanna pay the $$ for dynomat lol
so you guys are just using standard truck boxes? i see some for like 88-98 chevy trucks etc never seen one for 73-87 so iam guessing you guys are just buying standard truck boxes? |
#23 |
mine is just a standard truck box. only problem with a truck box is a lot of good woofers won't fit because the boxes aren't that deep. i have 2 lightning audios in mine and was pretty surprised at how good they sound i have no rattles or anthing. put out a decent amount of bass too. here are a few more pics. only have about $1000 in everything.
#24 |
where did u get that speaker kick panel thingy??????
so lightning audio fits? i use to have a la 10" havent tried their 12s |
#25 |
you can get the kick panel from crutchfield or a couple of other suppliers. come with infinity tweeters and i believe 5 1/4's or 6 1/2's. they are component speakers, don't cost that much and even come in your vehicles color. you can do a google search for kick panel speaker enclosures for the best price. the lightning audio 12's fit no problem, they aren't that deep. wanted hifonics woofers but all of them just had too big of a magnet to fit in a shallow box. i have the hifonics amp running the box and the concorde working the component speakers. the kickpanel enclosures are the best i've heard because the direct the mids and high's directly to your listening position.
