Old 04-10-2006, 12:04 PM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Air Bag Suspension Component List help...
Can any of you suspension gurus give us suspesion idiots a list of components needed for a complete basic air bag setup? I have some peices parts and a a pretty good idea of what I need but need some help. Like for instance can i runthe whole setup on a 4 port air tank or should I get a 2 2 port tanks?
Thanks in advance.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 04-10-2006, 12:05 PM   #2
Zumo
Hot Rods For Life
Zumo's Avatar
Re: Air Bag Suspension Component List help...
Oh this is for us "1 peice-at-a-time guys" who can't afford to get a whole kit at once.
Andy
Old 04-10-2006, 09:33 PM   #3
TravisH
TravisH's Avatar
I'm setting one 4 port tank up for my system.
You'll need:
-4 bags
-8 valves
-main airline
-gauge airline
-gauges
-switches
-relays
-compressor
-water separator
-fittings are kind of a custom fit, all depends on how you want to plumb the system
May be some other things but thats all I got off the top of my head. I highly recommend getting an 8 pack of SMC valves from suicide doors. Awesome deal on those.
Another thing to remember is bumpstop. One type of airbag (I think slam specialties) has built in ones but if you go with a firestone or airlift you'll need to make something up. For my rear I made a c-notch and mounted a bumpstop off the boxed plate to hit the axle and I've got an adjustable setup in the front
TravisH is offline   Reply With Quote
Old 04-10-2006, 09:53 PM   #4
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
Airlift has manuals online http://207.97.200.166/manuals.htm
That will show you how to plumb it and what componets you will need.
Jp Kustoms has all the fittings in a kit ( the only place I seen you can find them like that)
http://www.jpkustoms.com/main.shtml
1 piecing stuff is expensive and I would wait till the end untill the end to buy compressors and bags because if you have a problem they might be easier to return. Also you should have a specific plan and stick to it.
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 04-11-2006, 09:04 AM   #5
Zumo
Hot Rods For Life
Zumo's Avatar
Thanks guys. Right now All I have are a set of bags, plates and cup for the front which I got from a board memeber. They're used but the bags still hold air. I am going to put them on the back of my truck for now and use it for load leveling.
Anyone else?
Andy
Old 04-11-2006, 01:16 PM   #6
bodydropped
***************** sells kits but u can look at what kits they have and what u need
bodydropped is offline   Reply With Quote
Old 04-11-2006, 02:08 PM   #7
71swb4x4
71swb4x4's Avatar
All I can think of to add is a pressure switch, so your compressor knows when to turn on and a blow off valve on the tank is a good idea too.
I have also needed various brackets to mount the front tank, water seperator, and pressure switch, but each situation calls for a different bracket so I made mine.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
