10-03-2002, 07:50 PM | #1 |
Calling All Engine Builders
I've decided to rebuild my 402 BB from my 72 Longhorn. It's using a quart of oil every 150 miles. My goal is 425hp-475hp plus about tha same in torque. Keeping money in mind, I would like to get opinions on combinations and or modifications. I have a freshly rebuilt th400 behind it.
Fayette Alabama |
10-03-2002, 10:53 PM | #2 |
faster, faster, faster
bore it 30 or 40 over and a nice heads and a decent cam and you'll reach that mark.
I'm going to Law School, wanna debate? It's good practice. |
10-04-2002, 12:59 PM | #3 |
Livin' it up.
i concurr with my new 72, a good set of heads, and a nice cam and good CR would take you up there. Port those heads if you can and do all the matching possible. A nice hot cam with a good CR would take you to fun places, I'd say if you're building it for some nice power take the CR as high as you can with the gas you have available in your area.
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
10-04-2002, 04:07 PM | #4 |
Green club
Big 69, this was copied and pasted from a racer on team chevelle, he got that power level out of the 396 no problem on a budget. You could substitute a Holley 3310 and an rpm manifold, he used to run 11's in a full bodied Chevelle.
402 w / 10.3 to 1 compression (calculated) Edelbrock Performer RPM Q-Jet Manifold Q-Jet carb w / 75 main jets and 45B rods, AX secondary rods on a G hanger 1 3/4" primary tube headers w / 3" collectors (go with Dynomax) Factory lifter valley heat shield Factory carb heat shield and 1/2" phenolic spacer Moroso 6-quart oil pan Factory windage tray TRW aluminum water pump Factory 7 Blade thermostatic clutch fan HEI with power coil and mod. Ultradyne hydraulic cam - 280/288, 223/ 231 @.050 with .525/.550 ground on a 110 LSA and installed on a 106 Intake centerline with matching springs Crane long slot steel rocker arms Factory balancer Felpro gaskets Turbo 400 with transgo shift kit full auto valve body Factory deep pan ATI 10" converter # 408360(73P) 12 bolt with 3.73 gears stock front and rear suspension with 1 3/8" sway bars and No-Hop bars Polygraphite bushings 3" head pipes with 3" crossover and 2 1/2" tailpipes with Flowmaster Big Block Mufflers Series 50 Mallory Comp 140 fuel pump and regulator Factory 4-core radiator This combo was driven anywhere and with the Q-Jet got 13 MPG on the highway. With this cam you shift @ 5800 and with this valve lift you don't need a roller rocker. If it's a square bore carb you want then go with the HP series from Holley and stay away from the Demon which I believe is junk. If you have the $ and want to step up with the 396, I'd go with a roller setup. The problem is though that nobody makes a roller small enough for this combo but you might want to give Comp a call and see if they'll custom grind you one. Tell them you want a cam that's 232 / 238 @ .050 with .633 / .640 lift ground on a 108 LSA. This cam doesn't exist but they can grind it and it has my intake lobe as an exhaust lobe for your combo. Don't let them talk you into anything else. This setup will be 4-5 tenths quicker in the 1/4 mile and make power in the same range. However I don't recommend this for a daily driver rather for a weekend max effort car that will see regular trips down the 1320. BTW, this setup will set you back $1000 for everything. Still the key to everything here is having those heads done by the right people. Ideally you are looking for a shop that builds stock and super stock motors and this work should cost about $700. If you are assembling the motor make sure all your clearances are dead on.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
10-05-2002, 12:41 PM | #5 |
driving is in my blood
oval port heads with 2.19/1.88 valves, RPM intake, 10:1 compression, cam with around 225-235 duration@.050 and 1 3/4" headers will get you where you want.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
