Old 07-13-2006, 03:15 PM   #1
IGOR
IGOR's Avatar
Opinion please...
So - I'm going to attempt to attempt taking the tub off the frame Sat morning - I'm really jonesing to get my frame powdercoated - and I can get it done for free - I'm thinking I'm going to do it on the side of the house - cause my garage is barely big enough to hold flatulence...
Anyway - I have a nice concrete pad on the side of the house - and I drew this up today - a frame built from 2x6s - the Blazer will either be on top - or have another cross bar underneath - so that the A-frame is supported while I'm jacking the body up. The dimensions shown are purely reference and are subject to change and/or miscalculation. The lifting will be done with an engine hoist - this will merely be used to hold the tub - (not to string a hoist from)
Thoughts - opinions - any better ideas
I'm probably going to spray paint the A-frame chrome - just so it is a little stronger - (and so the neighbor has something nice to look at)
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 07-13-2006, 03:41 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Opinion please...
I'd attach the whole thing to a piece fof 3/4 ply wood to tie the bottoms of the legs together. It would be flat so you could roll the frame out from under the tub.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-13-2006, 05:02 PM   #3
makovai
makovai's Avatar
as i told you before i have a body hoist i used for my vette and a chain hoist with rolers it should pick it up no prob. after i got the body off i used a cherry picker to move it around.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 07-13-2006, 05:04 PM   #4
cdowns
cdowns's Avatar
i'd think you should put a small diagonial from the uprights to the cross bar to prevent it from a side to side wobble
Old 07-13-2006, 05:04 PM   #5
IGOR
IGOR's Avatar
I saw that - I just don't know how I'd support that - I'm not worried about lifting the body off the frame (or maybe I am a little bit) - I'm worried about supporting it securely outside -
-Ben
Old 07-13-2006, 06:02 PM   #6
bouncytruck
SKINNY TIRES RULE!
How about some braces out to the side.
bouncytruck 1972 K5
Old 07-13-2006, 09:42 PM   #7
IGOR
IGOR's Avatar
Oh look at you and your badself
-Ben
Old 07-14-2006, 01:28 AM   #8
RunTMCfan
RunTMCfan's Avatar
You would need lateral support somewhere. Whether inside the the legs (cross beam) or outside.
Rob
"RunTMCfan"
RunTMCfan is offline   Reply With Quote
Old 07-14-2006, 06:07 AM   #9
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
There ya go bouncy, now that looks a lot safer.
Chevyman63 is offline   Reply With Quote
Old 07-14-2006, 11:30 AM   #10
makovai
makovai's Avatar
id use more duct tape.
www.fast77.com
1996 Z71 w/ 35's
Old 07-14-2006, 11:40 AM   #11
bouncytruck
SKINNY TIRES RULE!
What about bailing wire?
bouncytruck 1972 K5
Old 07-14-2006, 01:10 PM   #12
Tynee
I miss this truck.
Tynee's Avatar
Don't forget the J.B. Weld!!
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 07-14-2006, 01:30 PM   #13
krue
Designated A-hole!
krue's Avatar
Overkill.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-14-2006, 03:31 PM   #14
xchevyxtc
I used 4x4's on those prebuilt metal sawhorses which i beefed up with some added shearing and the 4x4's broke. I then switched to 4x6's and it held the blazer's body up while i rolled out the chassis.. i used two 4x6's 10' in length and 4 of those sawhorses. just offering an example of what did and did not work for me. Hope it helps!!
xchevyxtc is offline   Reply With Quote
Old 07-16-2006, 07:49 AM   #15
Milk crates and drywall buckets is all I use.But,then again,I`m down to 1 1/2 arms,1 foot and my head is kinda flat on one side.I think they did a great job,though.Besides,who can see both sides at the same time?I always turn my head a little while talking to people in front of me.Oh!I have a safety tip:Make sure there are people around when you nab the milk crates.I thought the opposite and tryed when no one would see.Well,a guy from the store was goin`on a smoke break and musta heard me from inside.He grabbed his shotgun an put a load in my tail.I think I limp more from that than from the prosthetic.
Old 07-16-2006, 11:41 AM   #16
meathead95
computer illiterate
meathead95's Avatar
pm alexis about it he took his off with a cherry picker
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 07-16-2006, 02:08 PM   #17
vtblazer
vtblazer's Avatar
I've used the post's on saw horse thing brfoe but put in back on with a cherry picker.
I went slow and was very methodic but it still made for an interesting chore.
I had already sectioned off the firewall so it was a fair amount lighter.
vtblazer is offline   Reply With Quote
