Old 10-11-2006, 06:18 PM   #1
ole_blue_72
!!!!!!!!!!Brake problem!!!!!!!!!!!
Wooo Ole blue woooo. shew im havin a bad day with breaks. the rear breaks keep lockin up. i took everything off. thought they may be adjusted up to tight i backed them off and it seemed to make them worse. i have bleed them so i dotn think that that is what it is. the fronts seem to be workin no rust on the rotors. there was alot of break dust in the rear drums. also the master cylinder is leaking around the cap. i think i have it narrowed down to 2 maybe 3 things either the wheel cylinder or the mastercyclinder and i guess that the perpotioning valve could play a part in this as well. if anyone anyone else has had this problem any help would be great. ohh and the drivers side seems to do it the worst thanks for the help
ole_blue_72 is offline   Reply With Quote
Old 10-11-2006, 06:50 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: !!!!!!!!!!Break problem!!!!!!!!!!!
if you have not replaced the rear wheel cyl's do it ...even if they look good. REPLACE BOTH..
i had the same problem's and mine looked fine...as a last straw i replaced the wheel cyl's
no more problems at all..
rage'nrat638 is offline   Reply With Quote
Old 10-11-2006, 06:53 PM   #3
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Are the wheel cylinders leaking at all? Dried up fluid can allow the brake pads to grab the drum too soon. Current situation on one of my trucks... the right rear locks up all the time.
Proportioning valve may explain some of it but I don't have much experience in that field to suggest anything.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 10-11-2006, 09:29 PM   #4
ole_blue_72
the break dust in the drums was kinda gummy like it had been wet at one time i will replace the wheel cylinders first along with new pads. should i scuff the drums with sand paper to make sure there is no fluid left on them??
Old 10-11-2006, 09:45 PM   #5
centsless
sufficiently talented fool
centsless's Avatar
Replace the wheel cylinders and the brake shoes. Clean the drums with brakleen and then scuff them up with sand paper.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 10-12-2006, 01:42 AM   #6
ThatOneBlue67
Or have them professionally turned.
"The Hurricane"
1967 Chevrolet C10
Old 10-12-2006, 09:20 AM   #7
KEH
Better late than never
KEH's Avatar
I have the same thing going on...the right rear locking up. I think leaking fluid is the problem too.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 10-12-2006, 04:19 PM   #8
70GMCer
70GMCer's Avatar
Re: !!!!!!!!!!Brake problem!!!!!!!!!!!
Just went and bought new rear wheel cyls for $11.88 ea. at Advance Auto...
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-12-2006, 04:32 PM   #9
bryanw1968
bryanw1968's Avatar
Brake stuff is SO cheap now a days it's best to replace as much as you can with new. You can scrub, adjust, sand and rebuild wheel cylinders all you want but you still might have problems. IMHO
Good luck!
B-dub
bryanw1968 is offline   Reply With Quote
Old 10-12-2006, 04:41 PM   #10
ole_blue_72
thanks for all the help guys im goin to get the wheel chylinders this weekend and hopefully that will do the trick
Old 10-12-2006, 05:02 PM   #11
70rs/ss
70rs/ss's Avatar
It is also very possible that the rubber hoses can collapse inside. My rt front on a chevelle I had years ago locked and wouldn't release, my brother told me to put a new rubber hose and well it worked. If both were locking I'd see check this and even if not the hose goes bad from the inside out.
70rs/ss is offline   Reply With Quote
Old 10-12-2006, 06:57 PM   #12
qksilver
I agree with 70rs/ss, replace the hoses
qksilver is offline   Reply With Quote
Old 11-09-2015, 05:38 AM   #13
Cun-tree
Did the wheel cylinders fix your problem?
Cun-tree is offline   Reply With Quote
Old 11-09-2015, 06:49 AM   #14
Boog
laying low
Boog's Avatar
This is an old thread from 2006 Ashdown. The original poster hasn't posted since 2007. Unlikely he is still around but you may get some help here.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-09-2015, 06:55 AM   #15
Cun-tree
Cool, I didnt see it was that old. Searcy Arkansas. I have spent alot of time there. It is a nice town. Have a great day!
Old 11-09-2015, 07:09 AM   #16
Boog
laying low
Boog's Avatar
Yeah hey neighbor. Searcy's a good place to call home.
Just what kind of brake problems are you having? Go ahead and post up your particulars and questions. Plenty of good people here to offer help.
Boog
primer is finer
Old 11-09-2015, 07:36 AM   #17
Cun-tree
I just happened across this thread. I hadnt had the issue yet. Currently, I am missing some ebrake parts. I posted a introduction thread under builds. Yea, I used to love going to the flea markets in Judsonia. I used to hunt in Augusta, my granmother had a farm out there for a couple of years. I loved it.
