12-21-2006, 06:20 AM | #1 |
MY EX DRIVES A BROOM
serpentine belt conversion
I know there are few guys on here that have done this conversion. I have been searching and cannot find one post that goes through the whole installation, from donor vehicle thru special holes that need drilled to completion. Has any one got this info?
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
12-21-2006, 06:34 AM | #2 |
Re: serpentine belt conversion
I used the setup off a 94 4.3 on mine. Nothing really to drill on my crate engine. swap out the water pump, alternator and power steering pump for those that run on the serpentine setup. I took the hi pressure connection off the old power steering pump and put it on the newer pump that way I can use a stock (68-72 style) line.
12-21-2006, 06:40 AM | #3 |
I have just heard that in order to use your old style heads there needed to be some drilling done to one of them in order to use a set up off a 4.3.
12-21-2006, 06:52 AM | #4 | |
Only if you have the acclaimed "camel hump" heads that dont have any accessory holes in them.
12-21-2006, 07:26 AM | #5 |
blood type; Retumbo
if your heads have 3 holes on the front its an easy swap. other wise it can get real hairy.
12-21-2006, 07:31 AM | #6 |
Designated A-hole!
If you have the holes it's easy,
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-21-2006, 11:03 AM | #7 |
good, got the holes....now let me get this right.......all I gotta do is get a new reverse flow water pump for my engine, then go get an entire set up off a 4.3, 5.0, 5.7, whatever......replace needed parts, clean it and bolt it up to my engine, install electric fans then its off to the races.....is that everything, or did I miss something?
12-21-2006, 11:08 AM | #8 |
Born Psycho
if you decide to do it, let me know. i have a serp set up off a 4.3 astro van.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
12-21-2006, 11:20 AM | #9 | |
Global warming is a myth
Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
12-21-2006, 11:38 AM | #10 |
Keepin an eye out
I have a serp system ready to install the same time I switch to my aluminium heads, but one the one head is a mounting bolt hole short. From reading about the conversion I understand you can get by without this bolt. I may "add" the hole anyhow for peace of mind.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
12-21-2006, 12:57 PM | #11 |
sixty8C10...The only thing you have to watch for is if you get a setup off a 4.3, they had some with different size lower/crank Pulleys. No quick way to determine which 4.3 does which. Measure the dept of your harmonic balance and compar it to the one on the 4.3. If they are the same thinkness harmonic you are OK, if the 4.3 is narrower, then you'll have to get another lower pulley to get them to line up.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 12-21-2006 at 12:57 PM. |
12-21-2006, 01:23 PM | #12 | |
Thanks, Buddy
12-21-2006, 03:53 PM | #13 | |
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 12-21-2006 at 04:00 PM. |
12-21-2006, 04:44 PM | #14 |
That I do not know. My guess would be no, but I am just a shade tree (with no tree) mechanic
12-21-2006, 09:22 PM | #15 | ||
After all, a 4.3 is a 350 with two holes missin. Infact my neighbor uses SBC 6in rods and .040 over pistons in his Syclone.
12-22-2006, 03:16 AM | #16 |
It sounds simple enough, I am doing enough mods to my truck right now that alot of the little stuff like fuel lines, a/c lines will be easy.
