Old 01-11-2007, 12:21 AM   #1
byrd
Union Electrician
byrd's Avatar
Let's see some pics of shaved firewalls
I would like to see omse shaved firewalls, and also looking to know what to shave and why and what you did to make it as clean as you can.
TIA
Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 01-11-2007, 02:08 AM   #2
abadsvt
abadsvt's Avatar
Re: Let's see some pics of shaved firewalls
I also would like to know. I am going to be attempting mine probably next week!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 01-11-2007, 08:18 AM   #3
Rokcrln
Rokcrln's Avatar
Here are a few pics of a curent customer build I am working on. Check out "project lemon drop" for more pics.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-11-2007, 10:24 AM   #4
smoked68
smoked68's Avatar
thats awesome work. looks very good!!
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 01-11-2007, 10:53 AM   #5
byrd
Union Electrician
byrd's Avatar
Thanks Kevin,
I'm glad you posted that pic, I wanted to ask you about the rail you shaved off just below the ccowl, won't that let water rund down the firewal more since it doesn't have any where to go now, or am I
Zip:40272
Old 01-11-2007, 12:09 PM   #6
abadsvt
abadsvt's Avatar
Looks sweet Rokcrln! So what are you going to do with all the wires and stuff like the fuse block, speedometer wire, winshield wipers, ebrake and so on. I would love to do something very similiar to that. Thanks
Josh
(Project truck)
Old 01-11-2007, 12:42 PM   #7
pharcyde05
pharcyde05's Avatar
pharcyde05 is offline   Reply With Quote
Old 01-11-2007, 12:44 PM   #8
raggedjim
raggedjim's Avatar
Both of these are great work.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 01-11-2007, 02:15 PM   #9
1lowdiesel
1lowdiesel's Avatar
i like the yellow one b/c it all smooth it doesn't have the other humps in it.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 01-11-2007, 03:29 PM   #10
gregfull
gregfull's Avatar
Here's mine.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 01-11-2007, 03:37 PM   #11
cstm68
cstm68's Avatar
hey gregfull what color orange is that ??
cstm68 is offline   Reply With Quote
Old 01-11-2007, 05:56 PM   #12
gregfull
gregfull's Avatar
It's a 2005 Nissan 350Z color.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
09 Suburban
Old 01-11-2007, 09:50 PM   #13
mnunn454
mnunn454's Avatar
Originally Posted by gregfull View Post
Here's mine.
Gregfull, 'Just LOVE that color! Gorgeous. Nice project pics too.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 01-11-2007, 10:49 PM   #14
BCOWANWHEELS
i,am gonna do that to my firewall. they only rust i have on my whole truck is in the heater air intake across the front of the firewall and i was perplexed as how to fix it. after seeing how nice these firewalls look its going to be how i do mine except i want factory air . that lip removed across the top looks killer. chevy should have done that......
bob in tn.
BCOWANWHEELS is offline   Reply With Quote
Old 01-11-2007, 10:52 PM   #15
BCOWANWHEELS
when you remove the stock wireing harness fuse block what do you use in place of it ?
Old 01-12-2007, 12:44 AM   #16
brak
brak's Avatar
That looks alot like the color ppg made for project copperhead.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 01-12-2007, 12:49 AM   #17
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
for those of you with the shaved firewall, are you not running a heater?
i thought about removing mine because it will be parked for the winter, and i don't have AC, so there's really no need for a heater.
IvelDesigns is offline   Reply With Quote
Old 01-12-2007, 01:17 AM   #18
byrd
Union Electrician
byrd's Avatar
I will be using an aftermarket heat& A/C, only thing you will see is the bulk head where the four fittings will be for the hoses.
Zip:40272
Old 01-12-2007, 01:28 AM   #19
Rokcrln
Rokcrln's Avatar
On project Lomon Drop he has Heat and A/C and an 18 circut Painless harness and you will see none of it when finished!
Kevin
LFD inc.
Old 01-12-2007, 01:30 AM   #20
IvelDesigns
so where are the heater core lines going? is there a kit for this?
Old 01-12-2007, 01:48 AM   #21
cflvulcan
cflvulcan's Avatar
damn, my truck started off the same color then we added more tangerine and gold pearl in it to make it look brighter cause i didnt like it at first. your engine bay looks sick!!!
cflvulcan is offline   Reply With Quote
Old 01-12-2007, 01:57 AM   #22
cstm68
cstm68's Avatar
i used the painless 18 circut fuse block and chassis harness kit
part # 10206
Old 01-12-2007, 02:01 AM   #23
abadsvt
abadsvt's Avatar
part # 10206
So where did you put the new fuse block?
(Project truck)
Old 01-12-2007, 02:24 AM   #24
cstm68
cstm68's Avatar
i put it in the same spot under the dash, i just had the cut the whole in the firewall a little bigger.
i will post some pics soon!
Last edited by cstm68; 01-12-2007 at 02:27 AM. Reason: miss understood the question
Old 01-12-2007, 03:31 AM   #25
72armyswbtruck
72armyswbtruck's Avatar
That is one nice looking orange truck
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
