01-17-2007, 10:09 AM | #1 |
Body Swap
Hi there fellas, I'm new to this computer stuff so bear with me, I took me awhile to figure out that I was on the wrong forum. The question that I have is, I've got a 67 2wd 3/4 ton that the body is in fair condition, and I plan on putting it on a 71 4wd 1/2 ton frame, I know the doghouse's are different the 4wd being higher than the 2wd, will the cab fit on the 4wd without a body lift? Thanks in advance for any info.
01-17-2007, 10:50 AM | #2 |
Re: Body Swap
Everything should bolt right up. You will need to use the rubber body mounts from the 4x4 ( or get new ones ) and you'll have to cut out the floor area for the trany & tranfer case, and use a high bolt in type. You may also have to get bumper brackets for a 67 4x4 if your going to using original 67 style bumpers. I'm sure there are other things you'll run into but for the most part it's a bolt on deal.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
01-17-2007, 07:33 PM | #3 |
Re: Body Swap
3/4 ton body mounts are the same as 4x4 ones.It should be a swap with no mods required unless its a low hump floor in which case a high hump will need to be put in after you cut a hole in the floor...
01-17-2007, 07:37 PM | #4 |
Re: Body Swap
or add the body lift and not worry about the hump!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-17-2007, 07:45 PM | #5 |
Re: Body Swap
still have to cut a hole for the t case shifter though
01-18-2007, 02:35 AM | #6 |
Re: Body Swap
i think if the '67 is originally a TH400 or 4-speed truck it will already have the removeable high hump, so just cut the hole then.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 01-18-2007 at 02:35 AM. |
01-18-2007, 03:56 AM | #7 |
Re: Body Swap
if the 4x4 has the bolt in hump with a hole couldnt you just bolt that hump into the 67 (assuming the 67 has a boltin as well) then you wouldnt have to cut up a hump for no reason. JMHO...
-1947 3100 -1968 C10 -1970 K20 |
