Old 05-21-2006, 11:11 PM   #101
Sgt.Booya
Sgt.Booya's Avatar
Re: beating this question to death! LT1/4L60E
Great thread guys. Sounds like the work involved in this conversion is mind boggling, but I'm sure it's worth it. A reliable engine with 300hp and decent fuel consumption too!!
I've driven the LT1/4L60E police package for many years (when they still made them) and they kick some serious a$$!! They take a licking and keep on tickin' too.
Keep at it guys, don't lose the faith. Please update on your progress. I'll be checking this post often.
If you keep and open mind you never know what might drop in.
1970 Chev C10 SWB, "250 turbo thrift"
Sgt.Booya is offline   Reply With Quote
Old 05-21-2006, 11:21 PM   #102
Hart_Rod
Hart_Rod's Avatar
Originally Posted by shifty
hey wootdog, will that work with "red" coolant?
Why can't you use the factory radiator?
R
Hart_Rod is offline   Reply With Quote
Old 05-22-2006, 07:41 AM   #103
Wootdog
Wootdog's Avatar
Yes it will work with red coolant. I have been running that setup for over a year. I do have a electric fan setup with a electrical thermostat for the fan. Wootdog
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 05-22-2006, 07:48 AM   #104
Wootdog
Wootdog's Avatar
The reason I didnt use the factory C-10 radiator was because of radiator inlet and outlet sizes. You have to Jerry rig the hoses. There is also a steam pipe setup for the back of the heads. If you use the camaro setup, the hoses fit correctly and one of them actually has another smaller hose coming off of it for the connection to the rear of the engine. Wootdog.
1969 Chevelle
2002 Silverado LT
Old 05-22-2006, 12:30 PM   #105
jay-dawg
chevelito
jay-dawg's Avatar
damn...wootdog beat me to it. the c10 radiator is IIRC 1 1/2" while the LT1 has the 1 1/4" or 1" inlet/outlet.
wootdog...did you use the 3 row brackets?
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 06-11-2006, 11:58 AM   #106
pdr510
Junior Member
pdr510's Avatar
Here is a website where you can get the ac relocation brackets for the lt1's. I used this setup with out notching the frame. www.bowersrodshop.com/info_pulley.htm
pdr510 is offline   Reply With Quote
Old 07-31-2006, 09:23 PM   #107
Kenneth_CS87
Are you sending out your harness to get done?
Kenneth_CS87 is offline   Reply With Quote
Old 08-01-2006, 03:54 PM   #108
pdr510
Junior Member
pdr510's Avatar
I sent my harness about a 1 1/2 years ago. It works great!
Old 08-01-2006, 05:15 PM   #109
BowTieOgre
Where did you send your harness pdr?
Shifty, I could use the part #s for that fuel reg and filter if you still have them handy. Also, im going with a poly tank and external pump for $$$ reasons...any suggestions?
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 08-01-2006, 08:36 PM   #110
pdr510
Junior Member
pdr510's Avatar
I sent my harness to Lt1 wiring (www.lt1350.com)
Old 02-23-2007, 01:26 AM   #111
BowTieOgre
What is everyone using for headers with the LT1 swap?
Old 02-23-2007, 02:21 AM   #112
Kenneth_CS87
Im running andersons cc11dp headers.
Old 02-23-2007, 11:02 AM   #113
loweredd
www.loweredd.com
loweredd's Avatar
I used Hedman shorties for our trucks. Worked great!
loweredd is offline   Reply With Quote
Old 02-23-2007, 11:32 AM   #114
BowTieOgre
Right on, any idea on a model number? I will be looking in the meantime. Thx!
Old 02-23-2007, 04:09 PM   #115
Fastfun
Fastfun's Avatar
I am using Street & Performance headers
Fastfun is offline   Reply With Quote
Old 02-23-2007, 07:41 PM   #116
pdr510
Junior Member
pdr510's Avatar
I am using the Hooker Super Comps.
1970 C-10 Fleet Side
Gen IV 6.0 with 4L80E
Old 02-23-2007, 09:20 PM   #117
BowTieOgre
Dang Fast...now ive got a severe case of engine envy! Makes my LT1 look like a soup sandwich. Do you have a list of all the stuff you got from S&P with part numbers?
Old 02-27-2007, 05:55 PM   #118
tb8125
I just bought my lt1.
tb8125 is offline   Reply With Quote
Old 03-09-2007, 11:07 AM   #119
BowTieOgre
Ok, im running out of funds for the LT1 project so I am going low cost on the harness and PCM work. I just dropped $285 with Jeff from PCMAmerica. Ive heard mixed reviews but he seems like a good fella so im going to give him a try and let you guys know how it works out.
If I can scrape together the funds my next purchase is going to be headers. My only problem is all the ones I see in the catalogs are for the F or Y bodies and only 2 or 3 are listed for Impala/Caprice which is what I have. I would think that any D-port headers would suffice but im having problems find them for under $350. There is no way I can afford ceramic coated versions so im going plain Jane painted headers.
Whats the difference between long/mid/short tube headers? Is one better than the others?
Old 03-09-2007, 01:01 PM   #120
NPilot1975
NPilot1975's Avatar
Long tube are the best for performance and short are the best for fit most of the time. You can use any small block headers, you will just have to weld in bungs for the O2 sensors.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 03-09-2007, 04:23 PM   #121
Cochise
Junior Member
Cochise's Avatar
Originally Posted by mtwheels View Post
This is great info...I just bought my 72 C-10 over the weekend and am excited to get it started. I checked out your website minibike and the pics are great. Fortunatley, My father-in-Law has a police edition caprice with the LT1. I can basically have it. I have an I6 in it right now that has been overhauled. It has triple carbs, I thought that was cool, hadn't seen them before. The 6 will make it move...it's amazing. I can't wait to get the LT1 in though. I can't wait to get started with my new project. Any initial words of wisdom from anyone as I get started?
Thanks!
Only one word of wisdom from me. It is always best whendoing a project like that to take before and after pictures, and any other info you have and send it to JoeFrus@americanthunderbike.org May not make the job go well, but it could help me when I do the swap myself.
Cochise is offline   Reply With Quote
Old 03-09-2007, 05:22 PM   #122
Cochise
Junior Member
Cochise's Avatar
I just realized this thread has been going on since 2003.
Old 03-12-2007, 04:10 AM   #123
Kenneth_CS87
How did most of your guys resolved the AC Hitting the frame problem?
Old 03-12-2007, 12:25 PM   #124
BowTieOgre
Well I think there are 3 options...relocate the comp with the corvette setup, delete the A/C and run the delete pulley OR notch the frame for the belt. Since I live in the south and cant afford the vette setup im going to be notching.
Old 03-12-2007, 01:35 PM   #125
Kenneth_CS87
When running the AC delete does the frame still has too be nontch? How much has to be notch? any body has pics?
