Old 03-22-2007, 02:49 AM   #51
454_72_4X4
454_72_4X4's Avatar
Re: Would a tow bar be safe?
Originally Posted by Longhorn Man View Post
and grandpa and grandma wouldn't have ther ecar hooked to the RV with a tow bar.
Hey, hey watch your language.... I'm just over 40 and I tow a vehicle behind a 31 ft rv all summer, every summer! (My 72 in front of it all) hahaha
I'd hate to guess how many miles I've used a towbar.
Are they safe? Only as safe as the person doing the hookup and driving.
That leaves about 95% of the people on the road as unsafe for towbar use, or driving at all for that matter...
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-24-2007, 12:27 AM   #52
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Are they safe? Damm right they are - you just gotta respect them & what they entail. Ya gotta take longer to start & stop big time.... I got mine at Princess Auto on sale for 75.00CDN & all I had to supply were the bolts to hold it to the towed vehicle & the safety chains. See my origional post on pg 1 to see where it is at. I am a little sketched out by the "clamp-on-bumper" style of towbars. The whole idea just seems unreliable.... Get a bolt-on, remove the bumper & bolt it to the frame. Add some chains from frame-to-frame & voila! Order-up one new truck in your yard!
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 03-25-2007, 11:56 AM   #53
Rod
The fun begins towing with a tow bar in winter snow and ice. I dragged a 3 cyl Sprint home with a 3 cyl Firefly, 40 miles when the last gas crunch came about. If the towed unit can run I leave the towed vehicle running to keep the tranny juices flowing if its an automatic trans.
I have dragged many- many trucks , suburbans, blazers and assorted chassis in various conditions home...but used bigger vehicles than the sprint to tow with
When I mention Fun..its keeping your cheeks puckered. I wouldn't recommend towing in winter with a tow bar on ice roads. It's a sure way to jack-knife into something.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-07-2007, 09:06 AM   #54
bad_turbo
turbo enthusiast
bad_turbo's Avatar
I guess using a tow bar to pull a 25 ft. motorhome behind a 3/4 ton truck is out of the question?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 04-07-2007, 09:08 AM   #55
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen it done... but I wouldn't do it.
Old 04-07-2007, 10:22 AM   #56
longhorn71
longhorn71's Avatar
Here the chain and clamp to the front bumper tow bar is out lawed(if the catch ya!)The only style you can use here is the bot style ones.
I have 2 chain on ones one like the ones posted above.We towed many miles with it,no problems(INCLUDING A CHEVY 6500 DUMP TRUCK)
Here is a pic of the very old style one i have and I am not brave enough to use!!!
longhorn71 is offline   Reply With Quote
Old 04-07-2007, 01:39 PM   #57
Longhorn Man
I wouldn't want to use a clamp on unit myself... seen them used, I just wouldn't feel safe.
As for the motor home with a 3/4 ton tow rig... When we were rebuilding the frito lay trucks at work, this one cat could come and pick them up, he drove a dodge 2500 4X4 diesel, and hauled the P/30 with a cummins 4BTA and allison tranny with a tow bar, from here to St Louis every week.
Old 04-08-2007, 12:46 AM   #58
bad_turbo
turbo enthusiast
bad_turbo's Avatar
how about towing the 25 ft motorhome with a '98 crew cab dually? Thinking of buying one that is 75 miles from me and it doesn't run. The tow bill will be too expensive, so figured the tow bar would work with a big enough truck. Do they make tow bars that will fit without removing the front bumper?
Old 04-08-2007, 12:59 AM   #59
Longhorn Man
even though that cat was doing it... I HIGHLY recomend against it. Esp in your neck of the woods. The CHP would nail you in a heartbeat. If you rented a med duty box truck... a moving van for example, with electrick hyd brakes... then yeah, I'd say go for it. Still chreaper than a professional tow.
Most bars don't reqire bumper removal. I say remove it to prevent damage, and so you can bolt directly to the frame.
