04-06-2007, 10:40 AM | #101 |
Seņor Member
Re: Idea on cleaning up the back end...
and these...
Flames are gratuitous grinder fun, but you never know what may show up during paint.
04-06-2007, 07:56 PM | #102 |
Nice job!! Are you going to weld the studs in for the steps for a totally smooth look? Flames rock!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-06-2007, 08:12 PM | #103 |
Seņor Member
Si, knock the heads off the carriage bolts, then weld them into the top plate. That'll allow me to unbolt from the braces if I ever need to remove the bed.
04-06-2007, 09:51 PM | #104 |
'bout time ...
04-07-2007, 10:32 AM | #105 |
Seņor Member
License plate pocket. I wanted it to be as tight as possible around the license, rather than the typical squared-corner. It's pretty shallow, and will have a high-brightness white LED on the top to cover the required lighting.
04-08-2007, 01:08 AM | #106 |
LAIDOUT
Very nice work! Now that I am in the reassembly stage your picts make me miss the metal work stage.
Keep 'it coming! |
04-08-2007, 01:13 PM | #107 |
Seņor Member
A few more pics. Still having lots of trouble getting these back corners right. While it'd be nice to do a huge roll on them, it's not completely feasible because of the taillight mounting requirements. So I'm trying to get some major curvature on the corner area to mimic the like corner of the step fender. Time for the sandbag and mallet
04-08-2007, 01:15 PM | #108 |
Seņor Member
This shows a rough representation of the taillights location. Since they're so low (as is the license box), it's not a simple matter to just roll the bottom edge around.
04-08-2007, 02:02 PM | #109 |
If you had an extra set of rear fenders, you could cut the corners off of them and use to make the edge.
04-08-2007, 02:21 PM | #110 |
Rob.
Are you stuck on having them that low? I think they look good there or centered. Either way. Nice work as usual Last edited by Frizzle Fry; 04-08-2007 at 02:21 PM. |
04-08-2007, 02:54 PM | #111 |
Seņor Member
I could move the lights up, but the plate really won't fit anywhere else and still look right. If I moved the lights up, I could do a long bend up on the sides of the tail end, but I don't want it looking like this...
04-08-2007, 03:07 PM | #112 |
No, you definitely don't...
04-09-2007, 04:50 AM | #113 |
A guy with a truck
Agreed. Fenders or cab corners...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-21-2007, 01:08 AM | #114 |
Seņor Member
mini-progress... got the corners rounded out a bit more to my liking. I suppose I could pontificate this forever. Or... bust out the Bondo
04-21-2007, 01:10 AM | #115 |
Seņor Member
a few more
04-21-2007, 01:21 AM | #116 |
chevelito
looks better mang!
New deadline...when my son can drive. Aloha from Honolulu, HI |
04-21-2007, 01:35 AM | #117 |
"pontificate"... nice range on the vocab!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-21-2007, 12:11 PM | #118 |
It's not as truck related as stanchions.... but I give him an A for still frequently using that public school education .
XXL, the lines look to be identical to the fender corners which makes a huge difference. Nice vision as always!
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-21-2007 at 12:13 PM. |
04-21-2007, 03:40 PM | #119 |
Much better
04-21-2007, 03:52 PM | #120 |
what I'd like to do:
The top edge of bed side/ ends will have chrome cap found on 57 chevs.( kindof looking like fins from the side. * each end of side bed will look like a fin treatment found on the 57's, i should have added a roll pan to my illustration. -67-
1941 Chevy 1/2 ton Street Rod: 327 cu,/350 auto, 'Stinger ' - JULY 2007 CUSTOM CLASSIC TRUCK magazine. 1967 Chevy 3/4 ton standard bed, 350 cu./400 auto, w/ 83 - 3:43 rear end...sips gas.... Last edited by fourty1; 04-21-2007 at 03:53 PM. |
04-21-2007, 04:18 PM | #121 |
Seņor Member
I had the Spectacles of Prescience* on... which always helps
* +2 hit points
04-26-2007, 11:17 PM | #122 |
Seņor Member
femto-progress...
04-26-2007, 11:18 PM | #123 |
Seņor Member
and...
Note: The camera trickery is driving me nuts. It is NOT as flat as these pics makes it look.
04-27-2007, 01:03 AM | #124 |
It is taking shape. Looking good. Put some mud on it.
04-27-2007, 01:28 AM | #125 |
GEARHEAD
I like this build alot, that coming from a fleetside guy.
Very nice work. RJ22 |
