07-15-2006, 07:54 PM | #1 |
Seņor Member
Idea on cleaning up the back end...
I've tended to hold back a little, so as not to go "too far over the edge" (yes, my truck is a conservative take), but I've been inspired by Frizzle Fry's hybrid project body lines to push that edge just a little bit. The bed half of the Wallet Eater is in progress, and I recently finished doing a double wall on it. I also picked up some mandrel bends to do the trick Frizzle Fry did. But I've been wanting to clean up the lines on the tailgate area. Here's a q&d pshop of an idea... the gate is skinned with a bed side or a couple of door skins to get the body line crease and rolls of the side of these trucks. It flows smoothly into the rolled pan, which curls under and terminates.
Waddaya think?
07-15-2006, 08:01 PM | #2 |
Re: Idea on cleaning up the back end...
Sounds AWESOME! What is the corner cutout on the rolled pan for? Can the pan extend tp the edge of the gate?
Not that familiar with Steps - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
07-15-2006, 09:51 PM | #3 |
Designated A-hole!
Fits with the theme of your truck, but makes the bedrails seem out of place (look like mickey's ears ).
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
07-15-2006, 11:20 PM | #4 | |
Seņor Member
Wait... check the "Frizzle Fry" link in my OP. I'm laying out lines for cuts now.
07-15-2006, 11:50 PM | #5 |
computer illiterate
looks good
72 2wd blazer 72 swb 4x4 |
07-15-2006, 11:55 PM | #6 |
How about using some thin wall tubing and cut it from end to end to get the curve and the taper you are looking for from end to end of the tailgate and then you could weld flat sheetmetal the the pipe and the rollpan to get the desired effect. I think it would be difficult with door skins because I would say you would need at least two. Just a thought.
07-16-2006, 09:47 AM | #7 |
the door skins lines also don't match up from front to rear great idea, looks sharp i think a bed side or roll your own skin is the way to go, and yes you have to cap the bed rails
common sense isn't so common anymore Last edited by wibilly; 07-16-2006 at 09:49 AM. |
07-23-2006, 07:18 PM | #8 |
Seņor Member
Let the carnage begin!
07-23-2006, 08:04 PM | #9 |
Looks good. Where did you get the bends made at?
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-23-2006, 08:38 PM | #10 |
Happy to be here
Since your looking for opinions let me throw my spare change in. Extending the bed rails with the mandrel bends is a great idea. I also like the idea of adding the body line across the tailgate.
There are two more things I think it needs. I would look at extending the bed sides at the tailgate. This would create a smoother transition between the bed sides and the roll pan. The mandrel bends might work there too. I would do something with the filler panel for the tailgate too. Even though you added the lower body lines, it's still very flat back there. It needs a recessed area to break things up. Yes, I know you went through a lot of trouble to remove the factory recessed are there, but it's going to be too flat now.
07-23-2006, 11:19 PM | #12 | |
Seņor Member
07-24-2006, 08:50 AM | #13 |
67-72 Addict!
Those radiiused tubes make all the difference in the world. Looks really good not looking thru the open end of the rail.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
07-24-2006, 09:13 AM | #14 |
Some great ideas there. That's the best looking way to cap off the bed rails I have seen. I'm thinking about frenching some thin horizonal tailights into the lower rear of the fender. I think it will visually lower and widen the rear of the truck.
'69 swb stepside in progress. '59 Corvette lifetime project |
08-04-2006, 10:51 PM | #15 |
Seņor Member
Small progress this evening... first chance to work on the truck in a couple of weeks
08-04-2006, 11:24 PM | #16 |
looks great
08-05-2006, 12:34 AM | #17 | |
Happy to be here
Yep, those old cab corners would have been ideal for finishing off the lower part of the bed...
08-07-2006, 01:41 PM | #18 |
Seņor Member
Now to find a couple of door skins. Any suggestions???
08-07-2006, 06:30 PM | #19 |
GoodMark sells them. It might cost more, but will save you time cutting a door down.
08-08-2006, 12:55 AM | #20 |
Epoxy Primer Friendly
If you were closer I would give you some door skins..
08-09-2006, 05:02 PM | #21 |
Seņor Member
q&d of a door skin in place. I _think_ the scale is about right... I don't have measurements handy.
08-09-2006, 05:16 PM | #22 |
Seņor Member
complete...
08-09-2006, 07:21 PM | #23 |
Very cool idea. Get to work.....
08-09-2006, 08:09 PM | #24 | |
Seņor Member
08-10-2006, 01:38 AM | #25 | |
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
