04-04-2007, 11:28 AM | #1 |
99+^ Windshield Washer fluid container
need the one that mounts under the drivrs side on a 99+^ full size Truck, Tahoe, Sub, etc. Mine---the battery leaked down and wiped out the connections and or fluid tank. Huck
04-09-2007, 03:57 PM | #2 |
On the fast track to nowhere..
Re: 99+^ Windshield Washer fluid container
Have you taken it apart and looked yet? It's pretty common for the pump to start leaking at the seal where the top and bottom housings fit together or the tube to leak from the battery acid.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
04-09-2007, 08:37 PM | #3 |
Been too cold --but should be able to pull it out tomorrow. It is on my "low mileage" 02 truck. My 2000 with 163k miles --it's perfect!!
Is this "common" problem one I can fix without replacing parts? |
04-09-2007, 10:47 PM | #4 |
If it's a hole in the tube you can just cut it out and put a piece of vacum line in it's place. If it's the pump(most common) it will need to be replaced. If you can't find one used let me know. I work in a GM parts dept. and I'll get you a quote at my price.
