12-02-2002, 08:53 PM | #1 |
OK If I upgrade to power discs do I have to change the booster
Started looking for a front member today to replace the one on my 68 that has power drum brakes. Im looking for a 71-72 unit (with discs) but was wondering if it would be necessary to change the power booster and master cylinder with it. Anything else I should be concerned about.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
12-02-2002, 10:50 PM | #2 |
Fabricate till you "puke"
I think you will be ok on the booster, but will need to replace the master,lines & the prop valve.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-02-2002, 10:51 PM | #3 |
I have the power drum booster on my truck and did the disc conversion. The brakes work AWESOME at highway speeds (high vacuum), but at slow speeds, sometimes takes a LOT of pedal. I do have a Crower 270 cam however. I plan on swapping to the disc booster eventually when I get it off of my Suburban.
12-02-2002, 11:00 PM | #4 |
Active Member
You'll need a disc brake master cyl. and a proportioning valve. I like to buy new one's for reliability, their not that expensive.
I used my old power drum booster with no problems. Lines wll also be different so get everything you can from the doner truck, It will make life a lot easier.
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z |
12-02-2002, 11:05 PM | #5 |
My other Love
Mine as well replace the old sacked put booster anyways while everything is apart. Because brakes are somewhat important
MEMBER DISCS UP FRONT CLUB
Hooter_5@hotmail.com AC/DC RULES!!! First generation Monte Carlo club pictures of my life |
12-02-2002, 11:49 PM | #6 |
I found a donor vehicle (71) that's got everything complete on it so I'm going to look at it this weekend. Guy wants $50 for the stuff so I can't go wrong. He already sold the rear end out of it so I'll be hunting one of them next. 5 Lug on the front and 6 on the rear doesn't sound like a good idea.
Thanks everyone for the help. I'll be asking a bunch more ?'s once I get deeper into it.
