Old 05-12-2007, 11:34 PM   #326
Rokcrln
Rokcrln's Avatar
Re: Project Lemon Drop: anything but stock!
And here she is for the first time as a truck (well almost)! It started off today as a pile of parts and now it is ready for some fine panel adjusting and on to bigger things. I will add more later but now it is time to get dinner.
Kevin
LFD inc.
Rokcrln is offline   Reply With Quote
Old 05-12-2007, 11:35 PM   #327
Rokcrln
Rokcrln's Avatar
more
Old 05-12-2007, 11:36 PM   #328
Rokcrln
Rokcrln's Avatar
Last ones for now. Keep in mind it will still be getting cut and polished to bring out the shine!
Old 05-12-2007, 11:36 PM   #329
jimmydean
jimmydean's Avatar
Kevin, that looks gorgeous as expected. You have to be hapy with the results!
Now get that beast together!
<edit> I spoke too soon! Awesome.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-13-2007, 12:03 AM   #330
randomhero472
randomhero472's Avatar
looking good guys... keep it up!
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 05-13-2007, 12:20 AM   #331
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
wow..i dont know what else to say..i just spent over an hour catching up on this project...Roc, just awesome work man...the body work is outstanding, and paint is sweet..great color choice by the way..makes me want to change my mind on the color im eventually goign to pain mine,..
i would be so scared to have to move the parts..and if i painted somethign this nice, i couldnt drive it, i would be so scared it would get hit, or somethign like that...could be why i like primer and rust..lol
great job,,keep up the great work...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 05-13-2007, 12:31 AM   #332
jugernot
Life, Be In It.....
jugernot's Avatar
I just thought that we should tell you that it took THREE GALLONS OF PAINT to complete this project. Yellow is very transparent even with a white primer and a coat of white paint.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 05-13-2007, 01:44 AM   #333
BurnoutNova
BurnoutNova's Avatar
Originally Posted by jugernot View Post
THREE GALLONS OF PAINT.
i thought it was bad i used a whole quart of sealer on my box and hood...
that sounds like a little unforseen expence
BurnoutNova is offline   Reply With Quote
Old 05-24-2007, 08:11 AM   #334
seaquester5
New Member
I notice the detail you show in one of the photos of the firewall of what appears to be a bulkhead fitting for an a/c system is that correct?What system are you using? I am considering Vintage Air for my truck and have been told the Gen II system is better than the Sure Fit as you can obtain a cleaner firewall.Did you prefit an evaporator under the dash before paint, I don't see holes for one and assume perhaps bolts were welded on the inside at some earlier point? Clearly, your firewall is as clean as is obtainable so your thoughts on a system will be of great interest. Your project is certainly an inspiration,and look forward to watching future progress.
1948 Chevrolet 3600 all original perfect restoration
1976 GMC Grand Sierra 250 6 Cyl LWB Stepside All Orig, 49,000 mi
1972 LWB custom Frame off restoration in progress
seaquester5 is offline   Reply With Quote
Old 05-24-2007, 10:49 AM   #335
gregfull
gregfull's Avatar
The same goes for me too, my problem is that I didn't prefit, I'm kinda backwards sometimes. I like the entry point of the a/c lines. Truck looks great, what wheels are you going with?
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 08-26-2007, 05:05 PM   #336
LooseCannon
Any updates?
I also like the out-of-site bulkhead and wonder what a/c system you're using?
LooseCannon is offline   Reply With Quote
Old 08-26-2007, 06:35 PM   #337
bad6772
Official Site Guitar Shredder
bad6772's Avatar
hey kevin i hate to ask you a question . that im shure you get asked alot. but do you have any tips on shaving the drip rails... im starting this on my 72 next weekend and would like a few tips..do i need to do this with the doors on? and should i just cut off the drip rails in small sections and tack.? and did yoiu have to pie cut the roof anywhere? any help would be awsome..........i know when you got this project that it was already shaved, but it looks like you done a ton of work to them.........thanks tony
bad6772 is offline   Reply With Quote
Old 09-01-2007, 09:03 AM   #338
Rokcrln
Rokcrln's Avatar
Originally Posted by LooseCannon View Post
Any updates?
It is a Vintage Air system and I think the bulk head is also a Vintage unit.
Yes that is the bulk head fitting and the system we mocked it all up with was the Gen II system if I remember right. The lines will run up in the top of the fender untill they get tward the Rad support then they will duck out and hook to the compressor. Yes I did weld a few extra suports and mounting points so their would not be any holes comming thru th efire wall. This was the cleanets way we could come up with for running everything. I like the Gen II kit and wish I had one for my truck but I bought mine about 7yrs ago and they did not offer this kit that I was aware of. So in Low Buck it will come out right thru the fire wall but that is just how it goes. On my 2WD Blazer I am sure I will set it up for a Gen II system. The wiring will come out the same spot on the drivers side
My first tip is don't do it! I spent teh most time on this project just getting things right due to these cabs not being built all teh same even from side to side. It is alot of work to get things just right but if you do then it looks great. It is funny the two things I did not like when I started this project were shaved drip rails and Yellow. I even told Jugernot when I went to look at the truck before taking it on and he just told me that that is what he wanted and he knew it would turn out right. And boy was he right!
Back to your question, yes cut and tack small areas first and you will want yours doors set perfect before you start so you have a good referance point. As far as having to pie cut the roof it will depend on how it all welt together from the factory. The two areas in question will be at the front edge right at the corner were the door, the windshield meet and the "A" post all meet. They normaly are not in alignment and take alot of playing around with to get them to line up right. Good luck.
Kevin
LFD Inc.
Old 09-01-2007, 06:45 PM   #339
azfab
azfab's Avatar
man i like what u did on the fire wall! that chanel closed up looks sweet!!!!
azfab is offline   Reply With Quote
Old 09-06-2007, 12:10 AM   #340
wugunguy
70 C/10-Work in progress
wugunguy's Avatar
holy cow, just read the entire thread. That is some amazing work/talent. I just hope my '70 turns out half as nice as this will.
Great job guys
In the garage
1999 Dodge Dakota Sport-Daily Driver
1972 Chevy K/5 CST AC/PS/PB/4x4/Tow Hooks/Tilt
1970 Chevy C/10-Current project
wugunguy is offline   Reply With Quote
Old 11-01-2007, 05:34 AM   #341
Inthuwind
Straight jacket required
Inthuwind's Avatar
I can't believe I haven't read this thread!! This is truly an inspiration. Now I need to get back to the states and work on mine!!! Great work and great truck guys.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 11-01-2007, 10:22 AM   #342
67ChevyRedneck
67ChevyRedneck's Avatar
It's been five months or so since paint.... is she done yet?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-02-2007, 07:01 PM   #343
Rokcrln
Rokcrln's Avatar
No the owner sold their house the weekend we put the body together and last I heard the new house was not set up yet and all the extra boxes were still stacked all over the truck in the garage
Kevin
LFD Inc.
Old 11-04-2007, 11:11 AM   #344
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
why ? its a truck not a uhaul !
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 11-04-2007, 11:38 AM   #345
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 12-13-2007, 11:04 AM   #346
9teen69
9teen69's Avatar
Looks awesome! 7 yrs is nothing, I've had my 71 camaro since high school - going on 20 yrs. Great looking truck.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 12-13-2007, 03:25 PM   #347
ksbeatty
ksbeatty's Avatar
Where did you get that cab. It seemed so clean is there such a thing as a new cab for these trucks?
1969 GMC 3/4 Ton 4x4
2" Lift, A/C, PS, PB
383 Stroker, 700R4, 205, 4.10 GM
Medium Bronze (Copper Poly)
no new nick name yet. She is to pretty to be the Beater.
http://67-72chevytrucks.com/vboard/s...d.php?t=241855
ksbeatty is offline   Reply With Quote
Old 12-13-2007, 04:18 PM   #348
Rokcrln
Rokcrln's Avatar
Nope it started of as a regular rust job! He just wanted to spend the money and make it right!
Kevin
LFD inc.
Old 12-14-2007, 01:31 PM   #349
revn67
revn67's Avatar
i have always loved this build right from the start! it is gonna be a damn fine looking truck! it almost makes me want to keep my truck yellow instead of going blue......great job so far!!
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 12-14-2007, 02:44 PM   #350
Rokcrln
Rokcrln's Avatar
I am just starting the paint prep on LowBuck and it is going Blue of sorts But this yellow sure made me think twice!
Kevin
LFD Inc.
