Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 05-16-2007, 03:54 AM   #1
Padget
Padget's Avatar
Hi I Just bought an old chev pick up in SA
Hiya all, I just bought an old chev pick up, I really have no idea what it is yet. The registration book says its a 1972 Chevrolet C10.
Firstly this looks like a great site I've learnt more in 10 minutes here than I have in he last month of owning this truck. I'm in South Africa so I've no idea what type of spares I'll be able to get to fix her up. What I need is a reliable work horse so this ain't going to be no show gal.
It had no wiring loom no electrics, and has a small amount of rust, the upolstry is shot and the paint work is RO5 grey. I've managed to get it running and all the spark plugs are now burning a a healthy colour, I've wired up some electics so that I have Lights indicators and brake lights I've tightened the gear selectors up so she goes into gear, and I'll let you Know how I get on.
I'll post some pics soon so some one can tell me what it is that I have bought.
Padget is offline   Reply With Quote
Old 05-16-2007, 04:51 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Hi I Just bought an old chev pick up in SA
to the board
theres loads of info here for you pick at all you want, cant wait to see pics of your truck
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-16-2007, 05:14 AM   #3
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
To the board from Central, Pa, USA
You will love this place it rocks
Can't wait ta see pic's!
RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 05-16-2007, 05:18 AM   #4
Padget
Padget's Avatar
When I bought the truck in the paper work was an old photocopied spec sheet from a Chevrolet 3800 1972-1978 with the tech specs, such as the points setting, the cylinder firing order, and after weeks of banging my head thinking that this related to my engine I had, I finally gave up and threw it away.
I'm not a mechanic, but I have owned and loved Honda 750 fours all my life, I remarried a few years a go and with the new wife the bikes have all gone. So this truck is going to be my next project and as I sold my car to help my wife get the car she wanted, this truck is just going to have to keep running.
So I'm appling some basic motor cycle maintenance to a Chev truck and crossing my fingers.
The engine would only fire on No. three so I started from there putting leads to the spark plugs one by one, listening by ear until I had it running on all six . I then used a dwell meter to set the points gap. The points were set at about 1mm now its a lot less than that but the dwell angle is now at 32 degrees which feels about right. The carburetor by this time had blown all its gaskets from the back fires and the pre ignitions and lord knows what so I took it apart cleaned it out polished the inlet and stuck it back together, using a paper clip to hold the float in position. Once back on the manifold, I turned the fuel air mix screw in fully, and backed it out one and a half turns.
I started her up and she came to life eventually, I then backed out the air screw on the carburetor another one turn to get it to stay running while I cranked the idle down by 2500 rpm, and then with a home made rev counter from a Morris I turned up the fuel air screw until the engine revs started to die a bit then backed it out a quarter turn. Still using the rev counter, I then loosened off the distributor mounts and turned the whole body of the distributor clock wise then anti clock wise until I had the highest rpm.
I then went back and adjusted the carburetors fuel air mix and idle speed, and repeated the whole operation with the distributor. The vacuum advance retard doesn't seem to be working although I replaced the vacuum tube, so I have advanced the distributor about 5 degrees from where I had it at best set and locked it down at that. I'm hoping that the small advance will give me an easier start when cold, and take out any dead patches where the advance retard vacuum is not working. I have the engine now idling at around 850 rpm, and if i put my hand over the exhaust pipe it bumps against it very nicely with the occasional hick up about every 10 seconds, my hand is coming away clean and wet and smells hot and wet with a small hint of petrol, so its running a little rich which at this stage is OK. I'll get the garage to fine tune it with all their gizmo's when I have the money
I've taken the truck for a Test drive and wow! Its running very nicely thank you, the speedo goes up to 80 miles an hour and on the flat it goes up to about 72 of those miles an hour. Up hill the truck is showing its age and slows a little, but for normal use it seems to sit at 50 mph very comfortably and has loads of power left. There was a bit of smoke to begin with but that cleared up after it did about twenty miles. Back home all four spark plugs are burning a nice brown colour. There is some black oil in the threads of the lower end of the spark pugs and my guess is that the rings are on their way out or just well worn for its age.
I'm guessing that some of the oil sweeper rings on the pistons are a little worn, and hence the small amount of smoke and the loss of a little power up Hill. I'm wondering if its worth at a latter date having new rings fitted or having an oversize re bore. I'd really like some feed back on that.
The next job is to repalce the exhaust gasket if I can find one out here, as I did the last one some perminant damage trying to get the engine working when I was using the photocopied spec sheets. the firing order is not 1,5,3,6,2,4 Its 1,4,2,6,3,5 Can some one tell me is the timing 180 degrees out on the cam shaft or something, or is this anouther type of engine all together?
Old Chevs never Die
Old 05-16-2007, 05:21 AM   #5
Padget
Padget's Avatar
Thanks for the welcom Guys, I'm learning new stuff already. I'll take some pics later when my wife gets back with the camera, and learn how to post them then.
Old Chevs never Die
Old 05-16-2007, 05:24 AM   #6
Padget
Padget's Avatar
All four, all six ! never had a six before !
Old Chevs never Die
Old 05-16-2007, 05:32 AM   #7
RACINJASON22
GEARHEAD
I was gonna ask about the 4 but I see you stated 6 know
Sounds to me like ya got a good head on your shoulder there. Engines are engines and what ya know about one kind CAN be transfered over to most of the others.
I'm mostly into SBC's so I'm not much help on the inliners but, I do like em"
RJ22
Old 05-16-2007, 06:29 AM   #8
86swb
Born a Chevy Man
86swb's Avatar
Welcome to the board from Western Kentucky.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 05-16-2007, 07:29 AM   #9
rage'nrat638
rage'nrat638's Avatar
Talking Re: Hi I Just bought an old chev pick up in SA
welcome to the board from chicago
your pal mark
rage'nrat638 is offline   Reply With Quote
Old 05-16-2007, 07:34 AM   #10
L0WRIDE
L0WRIDE's Avatar
Welcome to the board from New zealand
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 05-16-2007, 08:58 AM   #11
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
from South Texas.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-16-2007, 09:08 AM   #12
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-16-2007, 10:00 AM   #13
shaneschevys
Its always something!
shaneschevys's Avatar
Welcome from FT Worth TX.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 05-16-2007, 10:02 AM   #14
jsbgump
Gone Fishing
jsbgump's Avatar
Welcome to the board from Texas
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-16-2007, 01:44 PM   #15
John Fabris
TOTY 2006
John Fabris's Avatar
Welcome!!!!
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 05-16-2007, 01:49 PM   #16
Padget
Padget's Avatar
Okay just took a few pics this is what I bought
Old Chevs never Die
Old 05-16-2007, 02:30 PM   #17
msgross
msgross's Avatar
That's a GMC grille in the US, someone might have added the bowtie to the hood.... nice short bed...
welcome
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-16-2007, 02:47 PM   #18
Padget
Padget's Avatar
Thanks Thats cleared a few things up
Old Chevs never Die
Old 05-16-2007, 02:49 PM   #19
1lowdiesel
1lowdiesel's Avatar
nice rig welcome from jersey.
i actually have relatives in the cape of good hope.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 05-16-2007, 02:59 PM   #20
redneckgirl
redneckgirl's Avatar
Welcome to the board from Maryland!!
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King
redneckgirl is offline   Reply With Quote
Old 05-17-2007, 12:23 AM   #21
Ron 586
RIP Mr Ron
Ron 586's Avatar
Welcome to the board from West Tennessee.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 05-17-2007, 11:08 PM   #22
CAL 58 GMC
CAL 58 GMC's Avatar
Welcome to the board from central California!
CAL 58 GMC is offline   Reply With Quote
Old 05-19-2007, 08:24 PM   #23
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Welcome To The Boards From The Great White North!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada!
- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs
- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 05-20-2007, 08:00 AM   #24
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
From West TN
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-24-2011, 05:45 AM   #25
ZUBZ
ZUBZ's Avatar
Nice truck Padget, wherebout in South Africa are you? We could maybe network as I recently purchased a 1970 C10.
ZUBZ is offline   Reply With Quote
