#76 |
Re: Killers 5.3L install
Man oh man, Killer how the heck are you sleeping at night, I would be so jazzed about having a drivetrain like that in my truck I'd be thinking about it constantly. Very, Very cool, 68short step may only be 23, but from what I can see he's a frickin genius, just the wiring alone would scare the crap out of me. Great work you guys, we're all drooling out here.
![]() Last edited by 71chevylowrider; 06-15-2007 at 11:55 PM. |
#77 | |
![]() ![]() nice work don! ![]()
R.I.P. Killer 71 10/26/07 |
#78 |
Hey don so is it correct to say that you won't be sending the wiring harness off anywhere to be fitted???
#79 |
A guy with a truck
Hey 68shortstep- any tips on wiring? Where'd you get your pinouts? Are you going to have to extend anything? Looks like you're gonna run the ECM in the Cab, correct? Deleting anything?
Killer- Looks good, man. Hope to see it on the local streets soon... Sorry for the hijack -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#80 | |
also on yours you have more wires then mine, since you have more sensors and a DOD setup.. |
#81 |
Excellent work. I'm following this one closely (literally.... I hope to get to see this first hand
#82 | |
#83 |
#84 |
DOD set up! Talk simple to me!
#85 |
A guy with a truck
Displacement on demand. Are you gonna try to keep it functional?
68- Where did you get all your info on what to keep and what to trash? I'm looking at all this spaghetti and need to trim the fat.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 06-16-2007 at 06:10 PM. |
#86 | |
EFI efficiency & DOD to make it even better on the highway. I hope it's possible to keep only the functions you want from the 'puter.
#87 |
yea we're keepin the DOD functional... and doing away with all the wires/crap we're not using...
gringo----- are you good at reading wireing diagrams? where i get the info is ALLDATA.com, this is what i used when i was a auto mechanic ,and still do use it.. |
#88 |
started to pull the truck appart... getting down to the frame to do all the install.. here are a few pics.... this is one REALLY clean truck!! no ceised bolts or broken anything... the A/C system is brand new and i believe he MAY be selling it (ask him, if instrested).... here are a few pics
![]() ![]() ![]() ![]() ![]() Last edited by 68 short step; 01-10-2008 at 08:45 AM. |
#89 |
Hey Don, wha, wha, wha, what happened to killer? Na just kidding, thanks for getting her covered up for me! Still hard seeing my baby get taken part, but it'll be worth it!
#90 |
#91 |
YIKES!
#92 |
got some work done to the rad support, smoothed the top and filled all the unused holes on the top of the support.. also located and mounted the fuses/relays to run the engine and trans..the rad. support turned out super good, better then mine.. so im pleased..
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by 68 short step; 01-10-2008 at 08:46 AM. |
#93 |
Now that's SMOOOOTH!!!
R.I.P. Killer 71 10/26/07 Last edited by killer71; 06-24-2007 at 11:03 PM. |
#94 |
![]() Join Date: Apr 2005
Is that a factory fuse panel?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#95 |
no its a aftermarket one..
http://www.currentperformance.com/Ac...iring_acc.html Last edited by 68 short step; 06-24-2007 at 11:29 PM. |
#96 |
A guy with a truck
#97 |
ok i've fixed it... link is above
#98 |
Questionable
It's the SA-1000 unit from Current Performance (Jared is the guy you want to talk to there). Rob, I have one downstairs if you wanna check it out when you come up, assuming you get time to stop by. It's a nice little setup.
68ss - question - why are you mounting the box there? Just curious. I was planning on installing mine in the place of the old fusebox and using that as the new fusebox ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 06-25-2007 at 01:07 AM. |
#99 | |
anyhoooo.. the reason i installed it there was its hidden, yet accessable..and it controls the engine, trans, sensors, fuel pump, a/c clutch, starter, etc... all of this is under the hood and it keeps things nice and clean by not haveing to have a bulkhead connection on the firewall to connect things from the inside the cab to the outside of the cab.. IMO thats how GM would of done it back in "the day" if thay had that technology, and they do mount the engine controls in the ehgine compartment now days... Last edited by 68 short step; 06-25-2007 at 10:16 PM. |
#100 |
I'm confused (that happens a lot
