08-02-2007, 01:14 AM | #1 |
Anyone gone with a diesel
I was wondering if any of you guys have thrown in a diesel? I got a 454 bored out .030 but was wondering if anybody has thrown in the duramax or 6.5 or other diesels. I have a K20 so probably would work better for the 4x4 guys but lets hear if anybody has done this.
08-02-2007, 05:49 AM | #2 |
Re: Anyone gone with a diesel
I`ve seen the 6.2s and 6.5s put in a few trucks.One was a guy that had oredered his`71 when new.Around 1990 he refurbrished the truck and had a 6.2 swapped-in.He just recently sold it.I have experience with these motors and would like to put one in a`72 I have.All I can say is if you can get a complete set-up to change over for cheap to nothing,it`s worth it.You won`t be "dropping" a Duramax into one of these trucks,though.It would be alot of work and e-x-p-e-n-s-i-v-e.They don`t share the common configuration that the Detroit-Allisons do and are fully computerized.So,1/2 the wiring and the transmission will need to come from the Duramax donor.
08-02-2007, 06:40 AM | #3 |
Active Member
Location: West TN (Memphis area) now. East TN (my favorite place to live).
I saw a diesel swap on PIMP MY RIDE. They put the DURMAX in a impala. The car ran great. Had the car running on BIO-Fuel. The car out ran a Ferrari in 1/4 mile.
BigFredTN 70 chevy stepside 350 with some goodies inside, turbo 400. 69 Chevy long wheel base. Dad bought new in 1970 62 Chevy Impala 98 GMC Yukon 1970 Ford Mustang Fastback I know its a Ford. |
08-02-2007, 10:10 AM | #4 |
Saw the same episode, that thing would fly! Ate the Ferrari for LUNCH!
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
08-02-2007, 10:42 AM | #5 |
Rottenwood Garage Member
Yep.............I swapped back to diesel the smart and quick way and it cost less than trying to do anything with a Duramax.
08-02-2007, 11:21 AM | #6 |
Project Junkie! Fishing Poor!!
Yep, me too... I was loyal to the lable though.. Duramax Rock!! WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
08-02-2007, 12:34 PM | #7 |
i,am going 4bt cummins in my c10,1971 and 6bt in my c30 dually in my 1972 both are bolt ins with no truck mod,s. needed. and the 4bt commonly gets hi 20,s in mpg
I BELIEVE IN JOHN 3:16 |
08-02-2007, 01:49 PM | #8 |
So I could just drop a 4bt or 6bt right in and bolt it up to the TH350 tran and be on my way without having to do a lot of mods? This has gotten me intersted now.
08-02-2007, 02:21 PM | #9 |
08-02-2007, 02:30 PM | #10 |
I guess that sounded kind of bad. Didn't mean to step on your toes there 72freak. I wish that GM would put a Duramax into a Suburban too. However my crew cab has lots of room too. It also gets 20 plus miles per gallon pulling my 24' fully enclosed trailer full of parts. WES
08-02-2007, 03:12 PM | #11 |
the 4 bt is a direct bolt in but you need a 400 th trans. a 350 th wont hold the torque of a 4bt. a 6 bt you have to fab engine mounts and go with a more h/d trans. as for the lame duramax yes they run good for a while but as you all know any engine with aluminum heads has problems with head gaskets. expansion rates are different and they start leaking then you run em low on coolant then crack heads & burn pistons. poor design for gm. you all know its made by isuzu dont ya for gm.
08-02-2007, 07:12 PM | #12 |
Know all u cummins guys don't get mad but. Do some reserch isuzu has been making diesels before cummins was ever thought of and hummers have been running around for the military with 6.5's w/ aluminum heads and never had problems in fact all vans and hummers had aluminum head 6.5's. My buddy has over 400,000 miles on his duramax with only a few problems, I know a lot of die hard cummins guys but it seems they all have problems and did you know that Ford is a partial owner of cummins in fact some dealerships service heavy duty cummins vehicles(service body trucks). My 6.5 which of course is gm(detriot) and I have 335,000 without any issues in fact all that has gone wrong is dead batteries, oil pick up fell off (welded it on when repaired), and ever since this new low sulfer fuel came out my liner in my tank came off and clogged the fuel system(not sure if the fuel was the cause but 2 of my buddies had the same problem recently) nothing else has been touched. To top it off isuzu and GM have been doing business for a long time same with gm and toyota (ie chevy luv, isuzu hombre, isuzu suv's where all made in the same factory with there chevrolet counterparts) isuzu is one of the best known diesel manufactures in the world (ie Catapillar engines) (huge oil liner ships etc etc. Dont be mad because the duramax's have more power pull better and last longer than pretty much all other light duty diesels manufactures the've only been doing it for over a 100 years. Back on topic find a wrecked duramax swap everything u can pick them up in an auction for 5k smashed in the rear or side, or run a 6.5 turbo, with the 6.5 pennisular diesel sells lower compression pistons so u can run more than the stock 7 psi of boost, and in doing this it will outrun any powerstoke or cummins on the road. Here check this build out it will show you how good the 6.5 can spank a powerstroke or cummins with just leveling the playing feild with even amounts of boost in all trucks
http://www.thedieselpage.com/finale.htm
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 08-02-2007 at 07:13 PM. |
08-02-2007, 07:52 PM | #13 | |
BCOWANWHEELS much love for you man I'm just stating the facts.
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap Last edited by Scott68-93-97; 08-02-2007 at 07:53 PM. |
08-02-2007, 10:02 PM | #14 |
say what you want but they all wish they were cummins. and pull down with the same year engine as your max and see who tops the hill first. the only reason the max dont have cast iron heads is because of cost cutting.
08-02-2007, 10:23 PM | #15 |
I think it would be awesome to have a 6.2 in my pickup. I've heard that they're not good engines but hell the military used 'em in their CUCV trucks and blazers so they must be good!
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
08-02-2007, 10:35 PM | #16 |
Is the 6.5 or 6.2 a direct bolt in as well?
08-02-2007, 10:44 PM | #17 | |
Now again, I am not trying to piss anybody off, just stating what I have seen. I do own a 3500 Dodge with the cummins (stock) and there is now comparison when it comes down to the grunt of a heavy load.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
08-02-2007, 10:50 PM | #18 |
I am not sure of the direct fit, but the 6.2 can be a good motor or the 6.5 . There are just slower than a herd of turtles. compared to the newer diesels. I have also had problems with overheating on these motors some say it is just a chararistic of them. Then again it could be I just had some bad luck with ones I have had.
08-02-2007, 11:47 PM | #19 |
Active Member
this raises another issue I would like to have answered:
what is the legal situation of swapping in a diesel? I am in texas, if that matters. |
08-02-2007, 11:50 PM | #20 |
Got a 5.9 cummins in mine!
08-03-2007, 12:57 AM | #21 | |
68 lwb to swb Cummins swap in the works. I promise it will be cool someday. |
08-03-2007, 03:15 AM | #22 |
If Ford is a partial owner of Cummins, then why is it that all Ford diesel engines are manufactured by International Harvester???
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
08-03-2007, 07:38 AM | #23 |
08-03-2007, 07:42 AM | #24 | |
Other than the emmisions issue...there are no other legal issues |
08-03-2007, 08:22 AM | #25 |
No emission laws in Texas on a diesel. I do know that. Plus we are exempt in our old trucks anyway, gas or diesel.
