Old 08-09-2007, 01:20 PM   #1
Don Brace
Active Member
Driveshaft Slip Joint Seal
The seal for the slip joint on my two piece driveshaft is shot. Where do you get a new seal? I dont think I can replace the seal because I can't get the collar loose. How do you keep the grease in the yoke without a seal?
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 08-09-2007, 07:58 PM   #2
JimKshortstep4x4
Re: Driveshaft Slip Joint Seal
I have had good luck getting the collars off by spraying them with penetrant, tapping around the collar with a hammer and then use a channel lock pliers to remove them. I have yet had to use heat, but that is an option.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-12-2007, 03:50 PM   #3
Don Brace
Active Member
Jim
Thanks for the tip. After soaking it for a couple of days and a few gentle taps with the hammar it came right apart. What a great board.
Don
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 04-11-2017, 02:43 AM   #4
Oscar73
Okay, so you got it off...where did you find a new seal?
Oscar73 is offline   Reply With Quote
Old 04-11-2017, 07:53 AM   #5
Don Brace
Active Member
Try LMC truck or Ecklers.
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
2- 71 Longhorns
Old 04-11-2017, 08:45 AM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
Any driveline shop will have them. How are the slip and stub? If they have lateral play they shouldbe replaced.
brad_man_72 is offline   Reply With Quote
Old 04-13-2017, 03:09 AM   #7
Oscar73
LMC, nope. Ecklers, nope. Driveline shops, pretty thin on the ground these days. Just re-used the old seal. It's a driver, not a showpiece.
Old 04-13-2017, 03:28 AM   #8
GR8-68
GR8-68's Avatar
How about you just go to your local Oreilly's and pick one up for 10.00
http://www.oreillyauto.com/site/c/de...1418&ppt=C0362
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
