Old 08-22-2007, 06:57 PM   #26
lofly'a
lofly'a's Avatar
Re: Any one Chop there Top???
those 2 trucks in the pics are laid back more than 3", i'll look for the article when i get home. that " lay back" is waaaaaay more than i want.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 08-22-2007, 08:19 PM   #27
piecesparts
Parts and more parts
piecesparts's Avatar
I purchased a 68 C-10 that had the top chopped 3" by a guy, in the Kansas City area, that has a lot of experience in this type of work. He cut the windshield first and then cut the top to match the glass. It is easier to do that than to cut the top and then match the glass to it. THe top was taken down in sections and there is a story in this month's issue of Sport Truck Magazine (Oct. 07)that is close to how he did it. I cannot find the welds in his work and it is very smooth, as is the door handle removal and the new mirror mounts (one piece windows)
Yes it is pink, that is the color of the primer/sealer---he planned on painting it red.
Old 08-22-2007, 11:02 PM   #28
Peter82
Everything is Custom
Peter82's Avatar
i would like to thank everyone for there input. i am going to go ahead a chop it 3 in. i could still use all the help i can get. any trick that could help. piecesparts... thanks for the hit about cutting the class first. do you know if they make a seal for chop tops or if we just cut the seal as needed??? thaks guys
Peter82 is offline   Reply With Quote
Old 08-22-2007, 11:24 PM   #29
Shane
Shane's Avatar
quick question ... where ya gonna get the front windshield cut?
Shane is offline   Reply With Quote
Old 08-23-2007, 01:37 PM   #30
Peter82
Peter82's Avatar
well i have to get a new windshield cuz my old one is pulling apart... i am think or taking it to a glass cutter or just use a dimond blade and cut it my self. i am going to go for the hole 3 inch's... good times
Old 08-23-2007, 05:27 PM   #31
crazy longhorn
Fabricate till you "puke"
I cut the glass in my chop top longhorn.....but, you had better know that it takes a glass cutter with 10-15 yrs under his belt to do that job! The flat glass (doors & rear), are no big issue. If you havent played with glass, you best leave that windsheild job to some of the better shops in your area. And no it wont be cheap! Most shops in my area were talkin 450-600 bones to cut that windsheild, & were totally honest(we may break 1 before we get the finished sheild....& you are payin for that one too!) Forget about your diamond blade.....I doubt it will work for you , my bet is it will bind & break your glass I have been running my 4" chop top since the mid 90's, & love it. However, for a daily driver, I would do a 2 1/2-3" chop as a max figure. Best of luck, L Oops.....pics http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-23-2007, 06:42 PM   #32
piecesparts
#1 There is no seal made for a chop, due to so many differnt chop top ideas. However a good glass guy will make the factory seal fit like a glove, mine did.
#2 The glass cutter is the trick and keep in mind, he may have to cut a couple windshields before he gets it right. That is on your billfold and not his. Mine was experienced enough that he got it right the first time. A good cutter will grind or polish the glass to size and not use a glass cutter--so to speak.
The guy that I used has had people fro all over the USA come to their shop, since they are the best. He owns Sunrise Glass in Merriam, Kansas. Many people said they tried many and then ended up going to him.
He did m y glass and made a special rear window for my truck ---including drilling holes and have the rear glass heat treated so that it wiill "POP OUT" like a van's window for about $600.00. I got off cheap for what I had done.
Old 08-24-2007, 01:03 AM   #33
Peter82
Peter82's Avatar
well are you able to tell me the name and addres of the shop that did your glass. maybe i can ship them some glass to cut. and i think i like the 4" chop.
Old 08-24-2007, 03:11 AM   #34
brak
brak's Avatar
I don't know who's truck this is, but i found it on this site a while back...
In my opinion, it looks *****in
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 08-24-2007, 09:14 AM   #35
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Heres pics I have saved back, have to squint to see out the back glass.LOL
sneakysnake is offline   Reply With Quote
Old 08-24-2007, 09:44 AM   #36
CG
BlahBlahBlah
Here is a pic from Bonneville this year. I actually think it looks pretty good. Im not usually a fan.
Old 08-24-2007, 11:59 AM   #37
piecesparts
If you look in the middle of the post, I gave the name of the company. However, here is more info.
Sunrise Glass CO
9003 Johnson Drive, Kansas City, KS 66102
(913) 722-5167
The name of the owner is Todd Craft
Every person for his own--4" chop was to much for me.
His dad started the business and he learned well from him.
Old 08-24-2007, 12:45 PM   #38
blacktruck
Super Trucker
IMHO... the roofline on the 67-72 trucks was one of the few things that gm got right the first time. i've never really cared for the chopped look on these particular trucks. that's just my $.02. i can see where if people didn't do this type of thing then every truck out there would almost look the same and make the customizing of these trucks a stale and predictable cookie cutter operation. which defeats the purpose of customizing. to each their own.
American by birth, Southern by the grace of God.
".. you aint just whistlin' Dixie..."
Rebel till I die
blacktruck is offline   Reply With Quote
Old 08-24-2007, 01:27 PM   #39
jb4short
Damn Yankee
jb4short's Avatar
Cut the whole thing off and put a '57 T-Bird windshield frame and vent mirrors on it....much easier.
jb4short is offline   Reply With Quote
Old 08-24-2007, 04:04 PM   #40
see ten
WTB this ad
see ten's Avatar
That's the best lookin chopped truck in this entire thread!
see ten is offline   Reply With Quote
Old 08-24-2007, 04:34 PM   #41
Lated
Lated's Avatar
I like the way the step sides look chopped better than the fleetsides, not sure why though. I'm planning on having mine chopped to just above the vent window hinge this winter but we'll see what the wife has to say about that. I played with a pic of it in paint and this is what I came up with.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 08-25-2007, 09:47 PM   #42
Peter82
Peter82's Avatar
Well i am really glad i opend this thread. i have seen a lot of pics i like. i think i am going for the 3 or 4 inch chop. i love the pic above this post. nice job guys.
Old 08-27-2007, 05:08 PM   #43
swiny20
I have a 72 real similar to the pick posted earlier from Bonneville. I'm working on getting some pics. I know there aren't many fans of chopped tops, but my grandfather did this one back in the early 80's and I just recently was able to buy it from a guy he sold it to. My grandfather had a major love for these trucks, he ran a body shop and restoring these trucks was his passion, He was killed in an auto accident in his favorite 70 SWB in 2002 and this 72 chopped top is the only truck I could locate that he had done. My plan is to utilize alot of parts off his truck to redo this truck. Unfortunately the cab was crushed, so I'm probably stuck with a chop top but I'm a fan of both you don't see many. This one has a personal value. I'll try to get pics on here tonite.
swiny20 is offline   Reply With Quote
Old 08-27-2007, 11:05 PM   #44
swiny20
Can't get pics to load not sure what problem is. This is all kinda new to me. Sorry I get them soon
Old 08-27-2007, 11:43 PM   #45
Shane
Shane's Avatar
Where are ya located in Alabama? Huntsville area here.
Old 08-28-2007, 12:19 AM   #46
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Sunrise Glass CO
(913) 722-5167
Sunrise does great work, they did the windsheld for my chopped 62 Ford unibody and also did a v butted windsheild for a chopped 40 Chevy I had. That was years ago, glad to see there still in business.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 08-28-2007, 09:08 AM   #47
swiny20
Yes, little north of Huntsville
Old 08-28-2007, 09:19 AM   #48
swiny20
Here are those pics, not the best but I quess they will do
Old 08-28-2007, 04:59 PM   #49
Shane
Shane's Avatar
North of Huntsville? Ardmore direction or Hazel Green direction?
I'm in Athens. Good to meet ya.
Old 08-28-2007, 06:13 PM   #50
piecesparts
The original owner, Larry Craft, had a heart attack few years ago, but todd has taken over and can do what his dad used to do. They are great people.
