creator of kong
Did you modify your indicator, or does somebody make them for these trucks, that has the P R O D 2 1 type of indicator?
didn't modify it, my pointer lands on the D when I'm in 4th, rarely ever shift to the other 3 forward gears...
------------------ '72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA http://www.ixpres.com/vlusardi/chevtrk.htm
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
14.1 @ 96MPH
I once saw an indicator for our trucks that had the OD / D / 2 / 1 indicators...I should've bookmarked it...I think I found it on a site in a thread regarding aftermarket gauges in the stock clusters...
------------------ Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete! ![]() |
Boosted Member
I simply do not have an indicator on my truck. The shift detents in the column work just fine with the overdrive. I believe that Dakota Digital has an indicator (L.E.D. or digital) that would work. Pretty pricey if i remember correctly (which is why i am indicatorless)
-Jeff --------------------------------------------- 69 C-10 LWB 67 C-10 SWB 92 K1500 Burban
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Running the stock 3sp column with a Lokar setup. I've been driving long enough to more or less guess where Drive is so its not a problem. Now when my wife gets in the truck (once every couple of years) it's a challenge since you have to pull the shifter towards you like going into reverse or first on the 3 speed column.
It's almost an antitheft device.... ------------------ '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. Way too much money and time..But it's a hobby.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
I was looking at the column in a chevy van,(with auto od ) and it appeared to me that the indicator from that column might work.
Don't know for sure, but might be worth checking out. |
![]() Join Date: Apr 2000
I used all the origanal parts from the 350 I took out. When it points to 3rd its in 4th. I can shift it past 1st witch is realy 2nd and use first only.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
I just put one on my 69. I got it from Bowtie overdrives. I-DID-IT makes it. I removed the old housing and the old indicator window. I had to grind the new one a little to slide in the housing from the back. It looks great and the light still shines through it.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
Mixup, pictures? PLEASE!
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
No camara. I'll see if I can borrow one.
