Old 12-24-2007, 10:24 AM   #1
**grumpy**
**grumpy**'s Avatar
?? about Slam bags for my 66 short/fleet
Hey all.
I'm starting on my 66 short fleet this week during our holiday shutdown, and had a question or two.
I already have 2) Slam re7's and 2) re8's that I bought for a sold project.
Will these work on my 66 ?
I'm keeping the stock trailing arms. Maybe add 2" block under them, and going with a KP notch.
I just want to know if my slam bags will work, size-wise.
Thanks everyone, and have a great holiday.
**grumpy** is offline   Reply With Quote
Old 12-25-2007, 03:44 AM   #2
duane67c-10
duane67c-10's Avatar
Re: ?? about Slam bags for my 66 short/fleet
im putting re7 all the way around mine, i think the re8 will work on the back.
duane67c-10 is offline   Reply With Quote
Old 01-02-2008, 11:43 AM   #3
**grumpy**
**grumpy**'s Avatar
Will I have to worry about not enough psi at ride height with 8's out back?
I don't want to have to air it up too high to drive, at highway speeds...
I'm sticking with stock TA and stock spring location.
Just wanted to make sure 8's weren't too much.
Old 01-02-2008, 05:41 PM   #4
SCOTI
SCOTI's Avatar
Depends on where your ride height is.
My 68 had the larger Stones in back w/1.5" blocks. Using the bolt in style c-notches, my rear end @ ride height was .75" into the frame which required 30psi in the bags. This was a little too soft (bouncy) for my taste. So ..... during my suspension re-vamp I switched to a smaller diameter bag which would theoretically require more air @ the same height & eliminate that 'bouncy' ride I noticed w/o adding any more height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
