01-19-2008, 10:44 AM | #101 |
PorterBuilt Man Crush
Re: Porterbuilt 69
What do you need, and I will supply!!!!!
The 72 will live again |
01-19-2008, 10:57 AM | #102 |
Cereal Killer
Re: Porterbuilt 69
How do you get anything done with all these folks nose's up your butt?
If I dont do it....somebody else will. |
01-19-2008, 11:08 AM | #103 |
Digital Dude
Re: Porterbuilt 69
Dude, have you seen his butt?
01-19-2008, 12:33 PM | #104 |
Village Idiot....
Re: Porterbuilt 69
[QUOTE=porterbuilt;2535005]I still can't feel the tip of my left ring finger!
This has nothing to do with you not being able to carry your end of the trans! It has everything to do with that silver band on that finger!
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
01-19-2008, 01:43 PM | #105 |
Re: Porterbuilt 69
Some days I too wonder!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-19-2008, 01:47 PM | #106 |
3DrDwn--the 'burb not the band
Re: Porterbuilt 69
I could only be so lucky.... I've had an order with CC # supplied with another vender for over 4 months and still no suspension. It's sad I could build something myself if I had the time but I never thought I'd have trouble spending the money. I need a rear set-up that goes in as quick and smooth as the DM did in the front so I will continue to wait. Did just get my new frame in for the racebike and a few extra parts should be at the dealer next week so spending should slow down on it soon. Of course I do need to spend some at performance machine getting new brakes for my knucklehead and that will hurt some. Always something....
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
01-19-2008, 01:47 PM | #107 |
Re: Porterbuilt 69
Well... since it felt so good yesterday I had to get some more today! It's been so long that I almost had forgotten how much fun this stuff can be!
I cleaned up a couple hours early and busted out the driver's side fender. I shaved the marker light and went ahead and stripped the exterior.... mocked it up and stared at it for a while! I also had to unbolt the rear wheels and set it down on the drums so the rake wasn't so bad. Still not close to ride height in the rear... but will have to do for now!
01-19-2008, 01:48 PM | #108 |
Re: Porterbuilt 69
two more...
01-19-2008, 02:00 PM | #109 |
Re: Porterbuilt 69
looks sweet, what do you use to get the fender that smooth?
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
01-19-2008, 02:03 PM | #110 |
Re: Porterbuilt 69
So Nate when is this rear suspension going to be available. I am sure their are alot of us waiting to order? So what morot are you going with a 5.3 or 6.0L and what HP are you thinking it will put out after the two hair driers are fired up?
Nice job on the marker removal. It takes me way to long to do a seamless job like that but it is getting faster by the day. Kevin LFD Inc. |
01-19-2008, 02:14 PM | #111 |
Re: Porterbuilt 69
I made the marker fillers by taking a sheet of 18ga. that was roughly 12"x12" and rolled it on my english wheel until the contour matched the fender as close as I could get it (didn't take too long, the radius is subtle). I then cut out the filler piece (just big enough to remove the stamped marker recess hole), laid it on the fender over the marker light recess; traced my filler piece, cut-out the marked hole and marker recess, then made sure it all fit tight, fired up the TIG welder and stitched it in, allowing it to cool and using the hammer and dolly to keep it straight. Then I stripped the whole fender with a 36 grit DA, 60 grit DA, and finally an 80 grit DA.
01-19-2008, 02:17 PM | #112 | |
Re: Porterbuilt 69
It's a 5.7 out of a 02 SS Camaro. Came with headers, ported heads, under-drive pulleys, SPEC racing clutch, and who knows what internals... looked like the guy spent a bunch of money and then wrecked his car with all that extra power? I will be trying to keep it at around 600 hp. It will be capable of much more, but I would have to upgrade everything to be able to use that kind of power.
01-19-2008, 02:22 PM | #113 |
Re: Porterbuilt 69
600hp that sound a little conservative with twin turbos.
01-19-2008, 02:28 PM | #114 |
Re: Porterbuilt 69
Very conservative... with the proper tuning and internal upgrades it could make over 1000hp. I just don't want to spend the extra coin and or brake stuff!!! 600hp is plenty for me!
01-19-2008, 10:43 PM | #115 |
Re: Porterbuilt 69
01-20-2008, 12:23 AM | #116 |
Re: Porterbuilt 69
They're Boyd Cotterpin "ACE" wheels... they are BAD ACE!!!!!
I thought they looked cool in pics, but in person... WOW!
01-20-2008, 04:33 AM | #117 |
Re: Porterbuilt 69
Hey Nate how bout some pics of the conv. belair? Is that the one you were wanting to do the c5 drivetrain too?
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
01-20-2008, 06:45 AM | #118 | |
Life, Be In It.....
Re: Porterbuilt 69
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
01-20-2008, 06:52 AM | #119 |
Re: Porterbuilt 69
01-20-2008, 07:34 AM | #120 | |
Happy to be here
Re: Porterbuilt 69
01-20-2008, 08:22 AM | #121 |
Re: Porterbuilt 69
01-20-2008, 10:34 AM | #122 |
Re: Porterbuilt 69
Nate,
I see you're running the "Porterbuilt Signature" Wheels on the truck.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
01-20-2008, 11:06 AM | #123 |
Re: Porterbuilt 69
The image makes the center look like it has a sheen to it or maybe a brushed finish...at least that's what I thought. Actually, the center is a rough cast looking piece... pretty darn cool.
01-20-2008, 11:13 AM | #124 |
Re: Porterbuilt 69
Looks great! - any luck on the swaybar?
I am getting closer on mine. Ran fuel lines today. Curious if you have any close up on the motor mounts? |
01-20-2008, 01:43 PM | #125 | |
Life, Be In It.....
Re: Porterbuilt 69
http://67-72chevytrucks.com/vboard/s...=1#post2489088
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 01-20-2008 at 01:50 PM. |
