![]() Join Date: Aug 2007
Re: 2000 GMC Sierra 1500 4x4 drop?
How low are you wanting to go?
Up front you can do spindles and/or drop keys. Both will get you about 2" each. For the rear you can get a flip kit, shackles, hangers, or drop leafs. I'd start out with removing the block and then go from there. After you remove the block and you decide that isn't low enough make sure that you install a bolt in notch on 5 or more inches of drop. If not it wont be a very good ride..... If you need any more help PM me or post up here
