Old 01-26-2008, 08:45 AM   #1
olsofti
olsofti's Avatar
'71 G10 front rotors on '73-'87 drop spindles
I want to use wheels with 5x4 3/4 bolt pattern that I all ready have,on my '64 C-10 with '73-'87 drop spindles.
Does anyone know if the '71-'74 G-10 rotors and calipers will work with these spindles?
Thanks in advance.
olsofti is offline   Reply With Quote
Old 01-26-2008, 09:52 AM   #2
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Re: '71 G10 front rotors on '73-'87 drop spindles
Don't believe so...but you can check out AZ, Advance or O'Reilly's websites and look up both applications and see if they are the same part number. If memory serves me correctly I believe the newer spindles had a larger inner wheel bearing if it was the JB5 brake system.
ClassicAutoResto is offline   Reply With Quote
Old 01-26-2008, 10:01 AM   #3
olsofti
olsofti's Avatar
Thanks Rust. I looked up the bearings and they do have different part #'s. I guess I'll get the truck rotors and drill them to the 4 3/4 bolt pattern.
