Old 03-02-2008, 10:16 PM   #1
rick0312
rick0312's Avatar
SBC 305 cam question
i am rebuilding a chevy 305 for the truck. Looking to put some life back into the motor and was wondering if this cam set up would help improve the motors performance. What do you guys think?....thanks rick
http://cgi.ebay.com/ebaymotors/Chevy...7757QQtcZphoto
rick0312 is offline   Reply With Quote
Old 03-02-2008, 10:59 PM   #2
greasy68
greasy68's Avatar
Re: SBC 305 cam question
It sounds like a good deal. I have never done business with that seller. I am still a little worried about buying stuff off ebay but it does look like a good deal.
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
Old 03-03-2008, 10:47 AM   #3
rick0312
rick0312's Avatar
I hear the rv cam is a nice upgrade for this motor.
Old 03-03-2008, 08:18 PM   #4
Billla
Billla's Avatar
The problems with the 305 are lousy heads compounded by the small bore shrouding the valves. This limits the benefits that additional lift and duration will offer. That's certainly the most cam I would run in a 305.
I'm sure you've been told, but the best upgrade you can do during a 305 rebuild is to a 350
Billla is offline   Reply With Quote
Old 03-03-2008, 08:43 PM   #5
Blackbird66
A GM goodwrench 350 is a great motor, for less than a quality rebuild. ( machine work + parts) If you are not doing a full rebuild, and stay with a 305, We have installed the 300hp 327 cam gm cam with real good success in a 305 on several occasions. My personal experience is that factory replacement cams from gm are the best all around street cams.
Blackbird66 is offline   Reply With Quote
Old 03-03-2008, 09:03 PM   #6
Billla
Billla's Avatar
That would be the famous GM #3896929 or "390" cam which I agree is a great mild street cam, especially for small displacement engines. CompCams sells this grind as grind # 12-105-3 and GMPP as 12364051.
The mild GM cams are good picks for mild street engines, but any mods (intake, heads, exhaust, etc.) and the aftermarket cams start showing real benefits IMHO.
Old 03-03-2008, 10:57 PM   #7
rick0312
rick0312's Avatar
Thanks`i would love to upgrade to a 350, but it's just not in the budget right now. check out the driver side head i pulled off. I assume this is an intake port...No wonder the motor was boggy!
Old 03-03-2008, 11:42 PM   #8
Billla
Billla's Avatar
No, that's not an intake port. That's the exhaust crossover the heats the floor of the intake manifold. They always look like that, and it has no impact on performance. If you're doing an overhaul, you should know where the intake ports are
FYI, if you're having to grind the crank and machine the block, then the cost is almost identical to doing a 350.
Old 03-04-2008, 02:15 AM   #9
rick0312
rick0312's Avatar
I think you guys have convinced me...I am going with the 350 crate from GM.....thanks
Old 03-04-2008, 03:04 AM   #10
Billla
Billla's Avatar
Rick, I didn't mean the intake comment as a shot - my sincere apologies if it was taken that way.
I do think you're going the right direction - the 260 or 290HP GM crate engines are impossible to beat on price or quality for a daily driver engine. They also upgrade pretty well with some smart changes.
Just be sure to make sure all the seals are wet with a little oil, prelube the heck out of it and add a pint of GM EOS before starting it.
Old 03-04-2008, 05:32 AM   #11
truckdude239
truckdude239's Avatar
hey i rebuilt the 305 for my truck http://67-72chevytrucks.com/vboard/s...d.php?t=245056
i went witha stock cam but am thinking about pulling it out and putting an rv cam in it before puting it in the truck
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-04-2008, 05:47 AM   #12
Billla
Billla's Avatar
What did you spend, engine out to engine in? The point here is that it costs the same to build a 350 as a 305...and that a crate is cheaper than either.
I still wouldn't bother doing a significant cam upgrade with all the issues with a 305...
Old 03-04-2008, 05:50 AM   #13
jwcardy
wow that looks like fun...
-wes
jwcardy is offline   Reply With Quote
Old 03-04-2008, 09:03 AM   #14
rick0312
rick0312's Avatar
Hey Bill not offended at all! I am gratefull for all of the feedback you give, especially to first timers lik me! Thanks for the input! I started calculating the cost to rebuild the 305 as you suggested and came to the conclusion that purchasing the 350 is the way to go...so I ordered it tonight from my local chevy dealer online. i purchased the 260/hp for $1400. i decided on this motor beause of the better low end torque...oh and the price! I'll post a pic when it comes in and maybe you guys can suggest an intake and a decent carb. thanks so much!....rick
Old 03-04-2008, 09:08 AM   #15
corn
I bought an 83 half ton truck from a guy who replaced the 305 cam with a stock 350 cam. That truck felt like it had a 350 motor. If I ever own another 305, Ill swap it to a 350 cam...
corn is offline   Reply With Quote
